Old 05-04-2015, 12:40 PM   #1
24HFS Diamond plate damaging cushions
The old thread was too old to reply to, but I figured I'd try again in hopes that maybe someone has had the issue since I last posted. When folding up the dinette cushions for loading the bikes in, the diamond plate that comes up the wall isn't a smooth transition to the wall itself and it is starting to cut into the dinette cushions. From what I can see, it does not look like the dinettes can be adjusted at all to be further off the wall, but maybe I am missing something. Can anyone shed some light? Thanks.
klarowe is offline   Reply With Quote
Old 05-04-2015, 12:48 PM   #2
TURBS's Avatar
Fyi you "can" reply to an old thread.
You just have to click the little box acknowledging that it's over 180 days old.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-04-2015, 12:51 PM   #3
Gotcha. I didn't even notice the check box... Sorry.
Old 05-04-2015, 07:25 PM   #4
Taranwanderer's Avatar
So you're saying that the exposed edge of the diamond plate is cutting into the cushions? I might try to take a long piece of rubber tubing (small, like a fuel line or even smaller,) slit it open and affix it over the edge of the DP (like with glue, clear RTV, etc.). This would cover the exposed edge and prevent further damage, yes?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 05-05-2015, 05:55 AM   #5
I thought about that but the cushions are so tight to the wall that by adding anything, I don't think I'd even be able to fold the seats up. They are very tight to the wall.
Old 05-05-2015, 08:09 AM   #6
Ok...so if there's no room to slip a protecting cover over the edge, how about taking a Dremel with a stone wheel and grinding the offending edge smooth? It might be easier to take the DP off and bring it into your shop or put it on a table to do this, but it might work...
Old 05-05-2015, 02:12 PM   #7
Could you run a strip of the clear tape used to repair awnings down the rough edge?
Wallace
twiggw is offline   Reply With Quote
Old 05-05-2015, 03:07 PM   #8
The diamond plate is already so thin that I think filing it will just create more of a knife edge and do further damage. I am going to see if there is something the dealer can do since it is still under warranty. If not, the clear tape may be a possibility... I'll just have to find some very strong tape so the cushion doesn't just pull it off.
Old 05-05-2015, 03:15 PM   #9
strat56's Avatar
A thin bead of silicone caulk on the top edge maybe? I know you said it's very thin but putting a very small bead of caulk up there to cover the edge might be all you need.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 05-05-2015, 05:48 PM   #10
diamond plate damaged
un bolt cushion from the wall get some spacers and longer bolts put it back on wall it will clear the diamond plate
premo is offline   Reply With Quote
