Old 07-25-2014, 05:44 PM   #1
24HFS Dual battery wiring
I just picked up my new 2015 24HFS and have a question about how the 2 batteries are wired. First of all, there is no ground cable between the 2 batteries... which throws me for a loop right off the bat. The other odd thing to me is that the battery with both terminals being used goes directly to what I can only guess is a relay bank (behind a black plastic cover). The other battery (the one with only the positive terminal used) goes to a 120amp circuit breaker.
So my questions are; 1) Is this wired correctly? 2) What is the reasoning for only one battery going through the circuit breaker?
klarowe is offline   Reply With Quote
Old 07-25-2014, 06:27 PM   #2
WolfWhistle's Avatar
Are you saying the negative on one battery doesn't have a cable attached? Are they 12V or 6V? You might want to take the covers off and post a picture. My TH came with one battery, the (+) red goes to a circuit breaker, the (-) black to the frame. When I added the second batty I simply cabled positive to positive and negative to negative... battery to battery. Do you have a generator or generator prep option?
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 07-25-2014, 07:01 PM   #3
Yes it has a generator prep package. Battery 2 has one red lead (positive) to the breaker. Battery 1 has a ground to the chassis and a positive to the relay pack...
Old 07-25-2014, 07:08 PM   #4
Herk7769's Avatar
Do you have a commercial (house type) refrigerator?
It may be a dedicated battery/inverter for the fridge.
HAM CALLSIGN - KC3FFW
Old 07-25-2014, 07:41 PM   #5
Are you sure you wrote this correct? you running 24 volt? or are you using 6 volt batteries?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 07-25-2014, 09:52 PM   #6
Positive to positive and negative to negative is wired parallel which means it would maintain 12volts. Mine are neither... there is no negative wire connected to the 2nd battery. I have a standard elec/propane fridge, as far as I know, there is no DC to AC converter installed either (none of my 110 works without shore power connected).
Old 07-25-2014, 10:01 PM   #7
RSchleder's Avatar
The wiring as you have observed is, IMHO, not correct. It makes absolutely not sense to have 1 battery with only the + terminal hooked up to anything!
RSchleder is offline   Reply With Quote
Old 07-26-2014, 05:09 AM   #8
Herk7769's Avatar
Is it possible to take a few photos of your batteries and battery compartment? Something is going on and some photos will help.
Old 07-26-2014, 05:29 AM   #9
Witch Doctor's Avatar
Just sounds like someone did not connect negative to negative. So really you are running off of 1 battery. I would just connect them, leave the red to the fuse and disconnect that ground and ground your second battery instead after you connect the two negatives together.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 07-26-2014, 07:50 AM   #10
I got under the trailer a bit and did some tracing.. now it makes a little more sense. Battery 1 has power going to the relay pack (still not 100% that's what it is) and ground goes to the chassis. Battery 2 positive goes to the circuit breaker and then into the generator compartment where it just terminates (no generator at the moment). This makes a lot more sense as to why there is no ground... this way it can't short on anything. For now I can probably just wire it up in a dual parallel battery setup to get the most out of having 2 batteries. Especially since I will probably eventually just go with an add-on generator rather than the factory Cummins Onan which I know can be loud as hell. Thanks for the help!
battery, wiring
