Old 04-03-2013, 09:22 AM   #1
FunTimes27XLR's Avatar
27 hfs
Anyone have issues with the hot water not being hot enough?
FunTimes27XLR is offline   Reply With Quote
Old 04-03-2013, 09:33 AM   #2
TURBS's Avatar
Is it just luke warm?
You may not have the winterization valves fully open or at all.
Old 04-03-2013, 09:40 AM   #3
dmf564's Avatar
It could be like ours and the temp control knob on the wh was turned all the way down.
[SIGPIC]TV-2012 Ford F250 XLT Supercrew 4X4
TT- 2010 Jayco Jay Flight 17Z (traded)
TT- 2012 Coachman Catalina 30BHS (current)
Me and my wife with 3 kids love camping!!
dmf564 is offline   Reply With Quote
Old 04-03-2013, 10:23 AM   #4
It is luke warm, we did open the winterization valves so I will check the WH valve too.
Old 04-03-2013, 10:48 AM   #5
TURBS's Avatar
What?
Old 04-03-2013, 10:50 AM   #6
TURBS's Avatar
I should have also said wh by pass valves.
Sorry
Old 04-03-2013, 11:03 AM   #7
dmf564's Avatar
What?
My wh has a large blue knob that is the thermostat for the wh. When we got our TT the first time we used it the dial was turn all the way down. I only discovered this after the hot water was not so hot. I turned the dial up up and we had HOT water. I guess I just assumed they all have a thermostat.
Old 04-03-2013, 11:09 AM   #8
dmf564's Avatar
I will add that this was on our old TT. And it was not an electric start. I had to light the pilot light and the "blue" knob was on the gas control valve. I just looked at our new one and noticed that does not have this. As it is electric start. Sorry if I cause confusion.
Old 06-13-2013, 09:40 PM   #9
What is the "Winterization" valve? I suspect that may be my problem as the pressure is ok out of the shower for about 15 seconds then goes to almost nil.
BGG
Camarillo, CA
bikepsych is offline   Reply With Quote
Old 06-17-2013, 10:34 PM   #10
RFK
RFK's Avatar
I had the exact same issue. Luke warm water and no pressure to the shower. There is a valve under the bed where the blue and red lines meet. Close that off and things should work fine
Ray & Barb
2017 Chevy Silverado 2500HD 4x4
2020 Flagstaff 26 FKBS
2007 Harley Electra Glide Classic
:iwo
RFK is offline   Reply With Quote
Old 06-17-2013, 11:29 PM   #11
are these the low point drains ??
Uploaded with ImageShack.us
2005 diesel excursion
2005 hi-way star 24' v-nose roadrace trailer
2013 forest river xlr27hfs hyperlite
melk-man is offline   Reply With Quote
Old 06-17-2013, 11:52 PM   #12
TURBS's Avatar
Yep!
Old 06-18-2013, 12:01 PM   #13
rah.rrt's Avatar
Just my opinion but you should tie up that loop hanging down. Easier to do that than replace the whole thing when it gets caught on something. I went through the belly of my 27hfs and made sure the lowest points were the frame and axels. Everything else is above that.
rah.rrt is offline   Reply With Quote
Old 06-18-2013, 01:47 PM   #14
Where can one get those little caps for the drains? I've lost the one off the tank drain.
Also, do I need to drain the entire system each time I move the trailer?
Thanks.
BG
BGG
Camarillo, CA
Old 06-18-2013, 02:41 PM   #15
RFK
RFK's Avatar
I only plan to drain mine at the end of the season. I do bring the fresh water down to about 1/3 unless I plan not to have hook ups. Not sure about the caps. They look pretty close to the garden hose size but I haven't tried to know for sure
Ray & Barb
:iwo
