Old 06-03-2016, 01:52 PM   #1
27 HFS Flat tire
so i havent seen the camper since i parked it 2.5 months ago after our disney trip. i decided to bring it home and park it in the driveway since i wanted to fix the fresh water tank leak that developed leaving Disney, and other Mx things like lubing, washing, etc. well when i went to pick it up i saw the right rear tire was flat (5.5 psi). i didnt have anything and i only had 2 miles to the house, so i decided to limp it home.
i filled the tire with my compressor, which seems to have more water in the line then id like (another project in the works). since it was 9 at night i could hear a hissing in the tread of where my new found leak was. NOw, i measured the other 3 tires and they were perfect, 64-65 psi.
so the question is, should i just get the tire patched and call it a day, or replace the tire? idk how long it sat on the tire like that. i got the camper brand new labor day weekend and have only used it a handful of times since then, so the tire has plenty of tread on it still, but after hearing about camper tires not nesscarilly being the best from the factory im not sure if a patch job should do it.
MotoCrazy808 is offline   Reply With Quote
Old 06-03-2016, 03:33 PM   #2
Commercial Member
Here is what a tire with only about half your load looks like after 3.9 mi with 5 psi at 15 mph looks like inside.
That nice circumferential line is the permanent damage to the tire structure is.
Observation it probably did not get the puncture while parked so you drove it to parking lot after being punctured and loosing air. How many miles with how much loss of air at what speed?
IMO your tire should be scrap.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 06-03-2016, 04:01 PM   #3
any suggestion as to what tire would be good to get?
Old 06-03-2016, 04:36 PM   #4
Commercial Member
Since any tire can get a puncture you need to set that issue aside.
Before you change tires you need to identify what you like and do not like about your current tires (brand, design, size and Load Range) unless you want to change for the sake of changing.
Old 06-03-2016, 10:48 PM   #5
I wasnt going to change because of the puncture itself. i just have the stock tires that came with the camper, and so far i havent had any complaints? they seemed to have done the job so far without a hickup?
Old 06-04-2016, 09:44 AM   #6
Commercial Member
OK. If you are happy with performance of current tires and you have had them inspected by tire dealer after 3 years service and all, except the one that went flat appear Ok then all should be good.
RE the tire that went flat.
IMO it should be replaced rather than just repaired and re-applied as a primary tire.
From my picture you can see that driving on a tire with only 5 psi can do damage in just a few miles, even at very low speeds. If the tire is inspected and if the puncture is repaired with a patch and plug it might be acceptable as a spare but I would not be comfortable with having it as a primary tire on the ground.
Obviously this is your decision so I am just offering my opinion as an experienced tire engineer.
Old 06-04-2016, 09:50 AM   #7
Thanks for the insight
Old 06-04-2016, 05:26 PM   #8
northstar1960's Avatar
think you ruined the tire by limping it home .
northstar1960 is offline   Reply With Quote
Old 06-04-2016, 10:54 PM   #9
Play Harder's Avatar
I would get a new tire - not worth the risk
Play Harder is offline   Reply With Quote
Old 06-05-2016, 10:07 AM   #10
found the culprit...pretty go0d sized nail, something like 3-4" pretty easily on the inside. the rest of the tire inside and out didnt see any kinda stress cracks or anything. But, GreasePro wouldnt patch or plug the hole due to location anyway.
So for now, the spare was a match and had that swapped to the main wheel. which i would hope seeming how i bought this new labor day weekend last year. so it looks to be that i will buy a new spare tire.
I wana replace it with an "E" load tire. which to me just makes sense. the current tires are WEST LAKE STZ load "D," anyone have any opinions as to which brand they like or recommend? Depending on where i get stationed next year, im most likely going to replace the main 4 tires to whatever i get as the spare, and definitely an E load tire.
ID:	110192   Click image for larger version
ID:	110193   Click image for larger version
tire
