Old 06-25-2013, 10:57 AM   #1
27 HFS Generator?
I put some foam around the generator that was installed at the factory to try and muffle the sound. What is everyone's thoughts on it? Will it get to hot and not work properly? Is there a different solution to it? My wife and I haven't slept in the front room without a electrical hookup, but come tailgating season we will be using the generator.
Thanks in advance for your feedback.
2007 Silverado Crew Cab w/ 5.3L
2013 XLR 27HFS
1981 EZGO Customized Golf Cart
Yler4cy is offline   Reply With Quote
Old 06-25-2013, 10:58 AM   #2
Now the exhaust comes out below the generator through a pipe, so that shouldn't be an issue.
2013 XLR 27HFS
Old 06-25-2013, 12:44 PM   #3
wyo700's Avatar
From what I can tell with mine is all the heat comes out the bottom. Let me know how that works I may try that with mine if it doesn't cause any problems. But considering the gen is in the camper it may not. It's just something we haves learned to live with but we don't have our gen on at night.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 06-26-2013, 10:13 AM   #4
I figure I would try this and if it doesn't work I will just live with it. I actually haven't even tested the generator at night noise due to not having to use the generator.
2013 XLR 27HFS
Old 06-27-2013, 08:10 PM   #5
Lift up the BED, there you have the storage compartment. I packed the storage area surrounding just the generator with a bunch of old pillows and blankets. Otherwise this area just seems to magnify the noise.. it did help some, but it's a bummer that thing is located right under your head (literally).
I suspect your foam will help some.. but i doubt as much as what i suggested.
2005 diesel excursion
2005 hi-way star 24' v-nose roadrace trailer
2013 forest river xlr27hfs hyperlite
melk-man is offline   Reply With Quote
Old 06-30-2013, 08:58 AM   #6
I attached the foam to the compartment on the inside under bed and closed off area cant store any thing there anyway,works great a lot quieter.
fnron is offline   Reply With Quote
Old 06-30-2013, 05:22 PM   #7
.. but go the extra mile, stuff some old pillows and blankets in that small area to take up ALL the open space around the gen box.
Old 08-25-2013, 09:37 PM   #8
Any concerns with airflow for cooling of the unit?
BG
BGG
Camarillo, CA
bikepsych is offline   Reply With Quote
Old 08-25-2013, 09:43 PM   #9
BG
If you are asking me, I will know this weekend. Our tailgating season starts and we do not have access to power and it is suppose to be in the upper 90's. Hopefully it will shut down if it gets to hot? Ofcourse I will have the door open to allow for more ventilation.
2013 XLR 27HFS
