02-04-2013, 05:33 PM
#21
You got plenty of room in that garage for a ricer too.
02-04-2013, 05:41 PM
#22
This is a photo of the mounting bracket I made.
It is attached under the trailer between the frame cross members. It is mounted in the same area as the front tie down rings. This allows me to remove the wheel chocks and the floor is smooth, just four holes for each chock. I only had the one bagger in the shop, the rest were Dynas, Softails and Customs. But two baggers will fit.
John And Mary
2016 Venom 3311TQ
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (27) 2017 (32) 2018 (34) 2019 (35) 2020 (20) 2021 (5)
02-04-2013, 05:54 PM
#23
phat phrog stunt crew
the white one in the background looks good too from what i can see.
02-04-2013, 05:59 PM
#24
Both of these are bike's the DW wanted me to build for her. I just can't say no!
John And Mary
2016 Venom 3311TQ
02-04-2013, 06:22 PM
#25
Originally Posted by Kaboom
This a photo of the Harbor Freight wheel chock I used
Will the harbor freight hold up the bike without the kickstand while you strap it?
02-04-2013, 07:02 PM
#26
What chage did they make to the shower didn't hear anything about that
02-04-2013, 07:32 PM
#27
10x, The Harbor Freight chocks are designed to hold the motorcycle upright on a level floor. while you place tie down straps on. However I took the front cross bar off so the chock would fit in the tt. So unless they are bolted to the floor I would not trust them. I also place a strap through the front wheel and around the upright on the chock. I tried it out of the trailer and on a level floor and even with out the cross bar, (which has tie down points), the bike was held up right.
A person could install the chocks and then cut the cross bars to fit.
John And Mary
2016 Venom 3311TQ
02-04-2013, 07:55 PM
#28
if those bikes are of your wifes design, she has a very good eye/design sense, and you have good building skills.
02-04-2013, 07:57 PM
#29
I see you have a plate on the ramp to drive the bikes on. Is that to keep from nicking up the trailer? What size is it and what type of metal?
02-04-2013, 08:06 PM
#30
Thanks for the compliments. 10x, those are just rubber backed carpet squares. I use them to protect the trailer and frame on the bikes. With the trailer level, The ramp angle is just steep enough that a stock hieght FLHTC will just barely clear. The lower bikes will hit the trailer frame.
John And Mary
2016 Venom 3311TQ
02-04-2013, 08:28 PM
#31
Great idea!
03-31-2013, 07:10 AM
#32
Hi everyone. Just purchased a 2014 27HFS. Planning on hauling my 2010 CVO Ultra in it. I have Harley's version of the Condor Pit Stop. Wanting to haul the bike without bolting down the chock. Will the bike try and walk around or will the straps be enough to keep it stationary? Any advise on this would be greatly appreciated. Thanks
03-31-2013, 02:29 PM
#33
Oxxer, depending on how you tie it down it may want to move around some. If your pulling it forward and out from the front and pulling it back and out from the rear it should be fairly solid. It will be difficult to get a good forward pull due to the locations of the front floor tie down points. Personally I would mount the chock to the floor making it removeable.
John And Mary
2016 Venom 3311TQ
03-31-2013, 03:32 PM
#34
We have two bikes that we put in the back of the TH listed below. My wife's BMW R1100R rode great with unsecured condor chocks and four point tie downs. My Honda ST1100 which is close to 700 lbs and has more weight up high would shift while traveling. We ended up paying a independent RV tech. to lower our 100 gallon fresh water tank and install the mounting kits. Since then, both bikes ride in the garage well with no movement.
Take a few test runs and see what you think works for you.
Jim & Nicky
2012 Forest River XLR 29 MBV
2010 Dodge 2500 Cummings
Honda ST1100
BMW R1100R
04-01-2013, 02:20 PM
#35
Hey thanks for the reply's. I will have to figure out a way to secure the chock. Fresh water tank is right in the way. Have either of you ever heard of or tried a threaded metal insert? Years ago I bought a cargo trailer that someone had put theses inserts in (they did not go all the way through the floor) and they were flush with the floor. Very easy to remove the chock when not in use. Thanks again for your thoughts.
04-01-2013, 02:41 PM
#36
I just finished installing a condor in my new wpt30wr. I debated the same thing with the water tanks etc. I just finally stood there and went why dont I weld a plate to my wheel chock and then weld the plate that makes the condor removable to that.
I did add 2 additional chocks plus another center row to the standard chocks so I have 3 rows of 5. All I did was take the second chalk in, unbolt it from the floor, weld my plate with the removable mount to it and bolt it back down, do other steps needed, worked great!!!
04-03-2013, 12:24 AM
#37
Oxxer, They must have moved the tanks on a 2014 27HFS. On a 2013 there is room between the black water tank and the fuel tank. It is the same open area that the factory used to mount the forward tie down ring plates.
John And Mary
2016 Venom 3311TQ
04-03-2013, 01:24 PM
#38
I noticed that too
04-04-2013, 03:05 AM
#39
Yes there is room between the two tanks but due to the length of the bike the chock needs to be up to the wall. The black water tank is directly below the wall.
04-04-2013, 12:04 PM
#40
Now it just becomes decision time Drop the tank or fabricate extensions to the chock.
John And Mary
2016 Venom 3311TQ
