Old 02-04-2013, 04:33 PM   #21
rattleNsmoke's Avatar
You got plenty of room in that garage for a ricer too.
rattleNsmoke is offline   Reply With Quote
Old 02-04-2013, 04:41 PM   #22
This is a photo of the mounting bracket I made.
It is attached under the trailer between the frame cross members. It is mounted in the same area as the front tie down rings. This allows me to remove the wheel chocks and the floor is smooth, just four holes for each chock. I only had the one bagger in the shop, the rest were Dynas, Softails and Customs. But two baggers will fit.
Name:	xlr 27 hfs wheel chocks 004.jpg
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
Old 02-04-2013, 04:54 PM   #23
phat phrog stunt crew
the white one in the background looks good too from what i can see.
dwaynerz is offline   Reply With Quote
Old 02-04-2013, 04:59 PM   #24
Both of these are bike's the DW wanted me to build for her. I just can't say no!
Name:	xlr 27 hfs wheel chocks.jpg
John And Mary
2013 XLR 27 HFS
Old 02-04-2013, 05:22 PM   #25
10x
Originally Posted by Kaboom View Post
This a photo of the Harbor Freight wheel chock I used
Will the harbor freight hold up the bike without the kickstand while you strap it?
10x is offline   Reply With Quote
Old 02-04-2013, 06:02 PM   #26
What chage did they make to the shower didn't hear anything about that
rmcbride is offline   Reply With Quote
Old 02-04-2013, 06:32 PM   #27
10x, The Harbor Freight chocks are designed to hold the motorcycle upright on a level floor. while you place tie down straps on. However I took the front cross bar off so the chock would fit in the tt. So unless they are bolted to the floor I would not trust them. I also place a strap through the front wheel and around the upright on the chock. I tried it out of the trailer and on a level floor and even with out the cross bar, (which has tie down points), the bike was held up right.
A person could install the chocks and then cut the cross bars to fit.
John And Mary
2013 XLR 27 HFS
Old 02-04-2013, 06:55 PM   #28
if those bikes are of your wifes design, she has a very good eye/design sense, and you have good building skills.
Old 02-04-2013, 06:57 PM   #29
10x
I see you have a plate on the ramp to drive the bikes on. Is that to keep from nicking up the trailer? What size is it and what type of metal?
Old 02-04-2013, 07:06 PM   #30
Thanks for the compliments. 10x, those are just rubber backed carpet squares. I use them to protect the trailer and frame on the bikes. With the trailer level, The ramp angle is just steep enough that a stock hieght FLHTC will just barely clear. The lower bikes will hit the trailer frame.
John And Mary
2013 XLR 27 HFS
