Old 06-03-2015, 12:51 PM   #1
InTheSticks's Avatar
27HFS owners, some general Q's.
I have a couple questions, read a lot here but have a couple questions.
1. Anyone pull the gen compartment out/apart to make a pass through, I cant see myself ever installing a gen set in there.
2. Bedroom wall. Anyone mod this wall, it is a pain to get into the bed and out of (well one of us)? I know the awning, slide out and light switches are there, maybe leave a 1' wall so you could swing your legs around that to get out?
3. Maybe I missed it, but can you use that gas fitting near the steps to run a grill, if so what fitting would you need to attach there? I understand it is after the pressure regulator so that poses a slight problem or not?
4. Why is there no fan switch in the "bathroom", there is one in the garage.
5. Inverters, I know several have installed them, I have two that are going to get installed, 1 pure sine wave for the TV, other for general light/fans use, where did you run your outlets for those? Are the outlets we have considered brown or black? Seen brown and white online for sale no black.
Thanks,
InTheSticks
2013 F150 FX4 Crew Cab Lux Package
2013 Forest River XLR 27HFS
InTheSticks is offline   Reply With Quote
Old 06-03-2015, 02:20 PM   #2
HI, I have the same model unit
1, I think the bed would become unstable if you took it out you will have to make a new base for the bed, I like having the separate little compartment. I store our quick fill fuel stuff in there so it doesn't stink up the garage area, one thing i did notice about the metal box is that it did trap a lot of condensation in there, i think the door was either left open or something wet got put away
2 yes the wall is some what of a pain but i think it adds stability to the trailer, I wouldn't take it out
3 i believe you can buy a fitting at camping world to connect that to your gas grill if you wanted too
4. I ask the same question "why no switch for the fan", i can just about reach it and I'm 5-11
5 Our unit has a built in inverter for the lighting other built in items, I have not tried a coffee pot however the refrigerator and the microwave and bed lift work just fine with the built in one , we don't have a TV so it hasn't become an issue for us.
Berjr1 is offline   Reply With Quote
