Old 07-28-2016, 11:06 AM   #1
29 HFS
I have a question. We were recently camping. The camper was set up level. There was a heavy short rain and afterwards the a/c leaked water on the floor. Is that normal? Should I be looking for a reason? I am unfamiliar with what should have prevented any rain water from coming into the RV. Anyone have any thoughts? Thanks.
laurajean is offline   Reply With Quote
Old 07-28-2016, 07:59 PM   #2
STLfan's Avatar
It could be that you have a water leak or that the humidity levels were so extreme that it started dripping. Mine seems to do it from time to time.
STLfan is offline   Reply With Quote
Old 07-28-2016, 08:32 PM   #3
northstar1960's Avatar
make sure the condensate drain on ac is clear , also could be the seals around the ac /roof mating surfaces , has it done this before in the rain . if not then the humidity was so high in the Th that it condensed inside the ac ceiling cover
northstar1960 is online now   Reply With Quote
Old 07-28-2016, 08:36 PM   #4
Do I need to be up top with cover off or in rv looking up. The camper reside in a barn with a styro box covering the AC unit to keep out bugs and wasps.
Old 07-28-2016, 09:09 PM   #5
Play Harder's Avatar
Hose it down around AC unit with garden hose and see if u have a leak
Play Harder is offline   Reply With Quote
