Old 03-11-2016, 04:02 PM   #1
29 HFS Garage Size Question
How wide is the interior of the garage, and how much head room is there if you have both the bed and happi jack system lifted to the celing??
polishdon is offline   Reply With Quote
Old 03-11-2016, 05:08 PM   #2
northstar1960's Avatar
8' wide i only have the bed and when lifited i can walk under it with out hitting my head and i'm 6'2 .
northstar1960 is offline   Reply With Quote
Old 03-11-2016, 07:56 PM   #3
Mine is less than 8 ft on the inside 8 ft is outside width
2015 hyper lite 29 hfs / 2016 gmc 2500hd
lonb is offline   Reply With Quote
Old 03-11-2016, 08:48 PM   #4
John513
JohnRiordan's Avatar
Not sure, but I'm 6ft and I have to duck down.
JohnRiordan is offline   Reply With Quote
Old 03-12-2016, 12:50 PM   #5
I went out and measured. 92 inches wide between bed track on wall. 5'3" height in the middle. 5' on the outside ( frame work for bench hangs down )
Old 03-12-2016, 05:28 PM   #6
WolfWhistle's Avatar
Bottom of the bed...almost 74" And width between HJ tracks 91-1/2"
WW
ID:	101759   Click image for larger version
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 03-12-2016, 05:31 PM   #7
Length
Hyper Lite was sold
Old 03-12-2016, 05:39 PM   #8
I have dinette and bed in back. 63 inches is the best I get.
Old 03-14-2016, 09:17 AM   #9
Thanks everyone!!
Old 03-14-2016, 11:48 AM   #10
My wife and I got to go look at a 27 and a 29 this past weekend at a dealer in MA. I was happy to see the garage is flat and no beaver tail. That will be much easier to put our goldwing up on the center stand if need be.
EricV is offline   Reply With Quote
Old 03-14-2016, 04:15 PM   #11
EricV ... Just a suggestion but a wheel chock like rhe Condor is great; I use it all the time. Just drive onto it and walk away. No need for center or side kick stand. I use it when hauling it., too. It needs to be attached to the floor to aid in getting the front tire out of its "grip" but is solid as a rock.
WW
Hyper Lite was sold
Old 03-14-2016, 04:43 PM   #12
Thanks WW
I saw one of those at a rally once, looked great. When I get the rig I'll be looking for installation advice.
Thanks again
Eric
Old 03-15-2016, 08:11 AM   #13
Harbor freight sells a nice ride in chock much like the condor but only 69 $ as opposed to $300 . been using the HF unit for a yr now with over 4500 miles and it works great
Old 03-15-2016, 09:07 AM   #14
Harbor freight chock
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 03-15-2016, 09:10 AM   #15
Above is the HB chock that I use. Works great and I can take it out when I'm at my destination.
(Ignore the tractor next to the bike. I was testing out weight distribution. ...)
Old 03-15-2016, 10:12 AM   #16
looks good, I'll check it out. Thanks
I figured you were mowing a parking spot for the bike
Old 03-15-2016, 10:39 AM   #17
Got my condor off of eBay for $175 but it certainly isn't the least expensive solution
WW
Hyper Lite was sold
Old 03-15-2016, 10:44 AM   #18
Here is the parking spot for the bike when we are camping.
Old 03-15-2016, 10:55 AM   #19
perfect!
Old 03-15-2016, 11:12 AM   #20
That's the same set up I use. Also, the OP might want to look at the Titan chock. Works great to protect a bike if you are ever in an accident. Don't ask me how I know that.
BIRDS AREN’T REAL
