Old 05-16-2015, 07:46 PM   #1
29 hfs water heater basics
What are the ways to get hot water? I have only done it one way but I know I can get hot water electric and or propane.
I set up at the campground and go out and turn the switch to on at the water heater. So( I thought that was electric?) What is the other option. ..senior moment!!!!!
laurajean is offline   Reply With Quote
Old 05-16-2015, 07:49 PM   #2
wmtire's Avatar
This should help explain it all....and where the Propane/DSI switch is, as well as the electric heating element switch.
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-16-2015, 08:27 PM   #3
northstar1960's Avatar
There is a switch by the control panel in the bathroom , right next to the pump switch . this is for running on propane dsi is direct spark ignition , The switch in the outside access panel is for turning on the 120v electric element . you can run both for quicker recovery . I find either one will heat the 6 gallons pretty quick .When plugged in i use the electric element and save my propane
northstar1960 is offline   Reply With Quote
Old 05-16-2015, 09:56 PM   #4
Great, thanks for the fast response.
Old 05-17-2015, 11:01 AM   #5
Taranwanderer's Avatar
Just make sure there's water in the HWH before flipping the electric element switch to "on." If the tank is empty, you'll burn out the element.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 05-17-2015, 02:11 PM   #6
Thanks, greatly appreciated.
heater, water, water heater
