Old 06-29-2016, 08:53 PM   #1
northstar1960's Avatar
29 hsf slide controller location ?
wondering where it may be located in the 29hsf just for any future needs . also doesn't the gen prep package come with a transfer switch ? if so where can't say I've ever seen mine . i have the gen start switch but nothing to transfer power from gen to shore and back
northstar1960 is offline   Reply With Quote
Old 06-29-2016, 09:40 PM   #2
Play Harder's Avatar
Transfers switch is under bed left side - under small plywood cover - there is a space behind generator compartment and storage compartment
Play Harder is offline   Reply With Quote
Old 06-30-2016, 08:23 AM   #3
WolfWhistle's Avatar
PH is right... its automatic.. I rewired mine so my generator can power the inverter. The slide Controller is below the slide on the outside of the frame rail. It is good the keep Lippert instructs on how to bring in manually. WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 06-30-2016, 08:56 AM   #4
Looked for the transfer switch under there can't say i've seen it will need to look closer guess . i'll also look for the controller again .i know how to work it but needed to know where it was
Thanks for the input
cat, controller, location, slide
