Old 03-03-2015, 08:37 PM   #1
northstar1960's Avatar
29 xlr tires ratings
does anyone know the max carrying capacity of the stock tire on the xlr 29 hsf ? hoping these are not maxed out like the axles are
northstar1960 is offline   Reply With Quote
Old 03-03-2015, 08:39 PM   #2
don't want to have to get new tires all ready
Old 03-03-2015, 08:42 PM   #3
TURBS's Avatar
You'll have to look at the tire, it's posted on the sidewall.
Old 03-03-2015, 08:59 PM   #4
Dave_Monica's Avatar
??? The GVWR for the camper is usually the axle capacity plus the dry hitch or pin weight, so axles on all campers are always maxed out when at it's GVWR.
Dave
Old 03-03-2015, 09:04 PM   #5
Oh is that where it is . lmao . i would but won't even see my unit till April ;
I was hoping to get someone who knows . you know one that all ready owns the unit . it's not a spec i seem to be able to find
Old 03-03-2015, 09:07 PM   #6
Dave
getting axles ratings is not as easy as it might seem . they post specs but very limited specs . they do not get into the things that really matter and stick to the fluff stuff , but i guess that's what sales .
Old 03-11-2015, 11:48 AM   #7
Pretty sure they are D rated
GDavidHughes is offline   Reply With Quote
Old 03-11-2015, 11:51 AM   #8
If you look for one that is for sale you may find a picture of the tire and axle placard. shows the axle placard. http://www.hilmersonrv.com/rv/little...yperlite+29hfs
St225/75R15/D. So D rated
4400 lb axle.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-11-2015, 08:16 PM   #9
D rated can be a wide range from 2200 to over 2540 .
Old 03-11-2015, 08:23 PM   #10
Originally Posted by Happy Vibe View Post
If you look for one that is for sale you may find a picture of the tire and axle placard. shows the axle placard. http://www.hilmersonrv.com/rv/little+falls+mn/forestriver+traveltrailer/3827/forester+xlr+hyperlite+29hfs
4400 lb axle.
Looks like that unit has lots of options with a cargo of 2400 . the tires it seems are rated at 2418 . which gives a max load of 9672 , with a dry trailer weight of over 6900 and cargo of qouted from the dealer 3014 , or from what i can find 2700 brings a low total to 9600 . not cutting it close are they , but then again what do they care , you'll be carrying 1000 on the tongue
tire, tires, xlr
