Old 09-19-2016, 01:02 PM   #1
29HFS, Generator will not charge batteries
Went camping this weekend, used a Honda 6500 generator, lost all battery power half way through the weekend. AC/Microwave work, nothing else would off the generator, no awning, slide, lights, fridge. My battery master switch is on, what else can I check to troubleshoot this? I need my camper this weekend and was hoping to have this fixed. This is a 29HFS I am working on. Dealer is over 3 hrs away, no time to make that trip if its something simple I can diagnose.
Also do the lights, slide, awning, fridge, awning, electric beds, only work on battery power then?
ricky836 is offline   Reply With Quote
Old 09-19-2016, 01:23 PM   #2
Flybob's Avatar
Check the high current fuse(s) in the distribution panel and also check to see if there is one up near the hitch. They are usually 30-40 Amp fuses. If they are blown, you will have no 12V power even with working converter.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-19-2016, 01:33 PM   #3
I checked all fused and breakers inside the unit, I will have to look up by the tongue for one tonight after work. Thanks!
Old 09-19-2016, 05:10 PM   #4
Just spoke to forest rivers electrical tech, according to him since I don't have an on board generator my batteries aren't going to charge unless I take battery tenders with me as well. Does this sound right?
Old 09-19-2016, 05:44 PM   #5
Zoom's Avatar
Also check the battery disconnect switch. Mine is easy to turn and not make contact sometimes.
2015 XLR 29HFS Toy Hauler
2016 Ford F250 Lariat Crew Cab FX4 Power Stroke
2007 Harley Softail Deluxe
2005 Victory Vegas
Zoom is offline   Reply With Quote
Old 09-19-2016, 07:36 PM   #6
Kilday4's Avatar
With a properly working converter your batteries should charge anytime the rig is plugged into shore power whether it's a generator or hard wired 30 amp receptacle.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
Old 09-19-2016, 10:17 PM   #7
That's what I thought myself. Hmm I will have to use a multimeter and test some points around the system.
Old 09-20-2016, 06:07 AM   #8
Ricky,
There is a little reset button under the camper right by the batteries. It's where the battery cables connect to a junction panel right before entering the camper. There are pic in another forum, can't search right now.
Good luck...;-)
2015 XLR Hyperlite 29HFS (installing mods...)
2004 GMC 2500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 09-20-2016, 06:17 AM   #9
Ricky,
Search for this -
Battery disconnect will not power uo
This has the pic.
Old 09-20-2016, 07:35 PM   #10
Tore into it tonight, 123v going into the converter, 0V coming out, found my problem. Pretty sad for a 4 month old 2017.
generator
