29hfs Satellite connection
Hi All,
Thought I should pass this on in case there are any other lost souls like myself trying to attach a satellite dish to the outside cable connection on a 29hfs. Anyways after some trial and error, I discovered that the plate on the ceiling that has the satellite coaxial connection beside the coaxial antenna connection actually has nothing connected to it. What I had to do, was unscrew the coaxial cover from the ceiling and locate the black coaxial cable on the back side of it. Unscrew it and move it to the empty connector on the cover marked satellite and then you should be in business. Just remember that once you move this cable, if you happen to connect to a parks cable connection, that the other TV connections in the rear and the front bedroom will no longer have access, however they will still have access to the antenna.
