Old 11-22-2013, 09:03 AM   #1
305v14 water heater bypass?
Any one know if my my 305v14 viper has water heater bypass?
2014 XLR Viper 305V14
2017 Ram 3500 LB DRW
phuber9458 is offline   Reply With Quote
Old 11-22-2013, 09:14 AM   #2
TURBS's Avatar
I've not seen any camper without one.
But I've not seen it all either.
Old 11-22-2013, 11:54 AM   #3
Dave_Monica's Avatar
The problem is trying to find them. The bypass valves are usually located behind the WH as shown in the image turbo posted. There should be a removal access panel under a cabinet, in the pass-through, somewhere very close to the WH. The factory tries hard to hide them, but we usually find them.
On some of the new campers, the bypass valves are in the camper's docking station.
Happy hunting...
Dave
Old 11-23-2013, 07:07 PM   #4
Adh203's Avatar
I have a 2012 xlr 305v12 mine is in the pass through storage behind panel four screws to remove hope this helps
Adh203 is offline   Reply With Quote
Old 11-24-2013, 06:27 AM   #5
Thanks for the replies. I had wondered if they were behind that panel but have not looked yet.
Old 01-03-2014, 01:17 PM   #6
robert.beck.7737's Avatar
When you bypass the water heater do you turn all three valves to the off position?
Using Tapatalk
robert.beck.7737 is offline   Reply With Quote
Old 01-03-2014, 01:34 PM   #7
No...the valves on the hot and cold connections are off (handle perpendicular to the flow) and the valve on the line between is open...opposite of that show in the picture in post #2.
Dave
Old 01-04-2014, 04:38 PM   #8
Has anyone modified their hot water heater valves so that access is easier than having to contort to a position to look behind the WH?
Using Tapatalk
Old 01-13-2014, 09:48 PM   #9
XLRViper305V16's Avatar
No there is no bypass. I have a 305v16 and had to install a kit myself. Everything you need to get to is on the drivers side next to the water connection.
XLRViper305V16 is offline   Reply With Quote
Old 01-16-2014, 08:47 AM   #10
Mine came with the bypass valves installed.
305, bypass, heater, water, water heater
