Old 05-05-2015, 09:59 AM   #21
Had the same problem from first time out. As stated before, debris from the factory was found in the valve. Unfortunately the dealer that fixed it did a bad job and scratched the surface of the valve plate and it still leaked after they had it for 3 weeks. Fixed it myself by reversing the valve plate so the scratch was on the drain side.
palmetto rogue is offline   Reply With Quote
Old 05-05-2015, 10:40 AM   #22
Originally Posted by OldCoot View Post
I have a Flagstaff 5er and I just slit the underbelly in an H and put a pc of alum up inside and sheet metal screwed the slits back together. Found out mine had a long alum rod instead of a cable.
My under belly is hard plastic and cannot see where valve might be..FR/CC will not tell be apprxx where it is side or middle!!!! J
Jim in Halifax is offline   Reply With Quote
Old 05-05-2015, 10:42 AM   #23
Is it the plastic cardboard? If so, you can push on it a feel around to find the valve.
Old 05-05-2015, 11:16 AM   #24
No Very hard stiff plastic like plywood!!!!!...J
5th wheel, black, black water, leak, water, wheel
