Old 09-12-2014, 12:19 PM   #1
6 Volts in 395 AMP
Just looking for some input on where to put 2 6 volts in my 395 AMP. My last TH had a big area where the battery was to do this. With the battery under the hydraulic pump, there doesn't seem to be much room without modifying it quiet a bit?
Has anyone done this mod? I really don't want to run them to far apart.
Thanks in advance
bggrndodge is offline   Reply With Quote
Old 09-23-2014, 11:51 AM   #2
So no one is running 6 volts in their XLR's?
2015 XLR 395AMP
2011 Dodge Ram 3500
Old 09-23-2014, 12:03 PM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I'm not familiar with your specific trailer, but if you would consider AGM's they can be mounted anywhere, in any position and don't need to be vented.
But not cheap.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 09-24-2014, 06:48 AM   #4
I don't have a need for dual batteries but I would put the second on the other side that way weight would be even. On our 395 there is a spot that is the same as the right side.
the.wilsons is offline   Reply With Quote
