Old 08-30-2014, 01:48 PM   #1
A/C Question
I am camping and was curious.
It Is mid 90's high humidity.
The camper is new, the thermostat is set at 72. The ac runs for awhile and shuts down for 2-3 minutes and start again constantly. Is that normal? Seems like a lot of cycling for the fan and compressor.
laurajean is offline   Reply With Quote
Old 08-30-2014, 02:18 PM   #2
bubbles's Avatar
Normal operation. Not sure of frequency/time of shut down but typically it will shut down so as not to freeze up. It will resume normal operation when freeze issue dissipates. Did you not get an installation/owners manual in your data package?
Old 08-30-2014, 06:21 PM   #3
robert.beck.7737's Avatar
At 92 degrees ours seldom quits running. I don't think it is normal. I would get it checked before it costs you a lot if money.
Using Tapatalk
robert.beck.7737 is offline   Reply With Quote
Old 08-31-2014, 12:10 PM   #4
WolfWhistle's Avatar
Hi, Laurajean. You have the vent aiming at the thermostat... it has louvers at 180 degrees. Turn the vent in the kitchen away from it.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 08-31-2014, 02:13 PM   #5
Good tip....thanks...
Old 08-31-2014, 02:45 PM   #6
vinmaker's Avatar
my A/c pretty much runs constantly also when it is hot out. If I lessen the cold controls to less A/C then it will cycle thru a few times. DW and DS love the cool air so we tend to keep it on the coldest setting the whole time were are on vacation. I turn on the A/C when we first pull in and it is the last thing to shut off before we unplug shore power.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-31-2014, 05:13 PM   #7
2014 XLR 27HFS
dave961's Avatar
I'm camping in the Florida sunshine this weekend, and mine will only shut off if I set it to 81 degrees. Anything lower and it just runs forever. I should have gotten a shady spot. In the direct sunlight these tin cans get HOT.
Sent from my Transformer TF101 using Forest River Forums mobile app
Dave & Audrey
dave961 is offline   Reply With Quote
Old 08-31-2014, 05:38 PM   #8
NELA
Weezer's Avatar
Unlike our homes, an RV's insulation isn't all that great, so once it achieves the stat temp and kicks off, it's more likely to kick back on sooner.
Also depends on how many folks are camping and/or how much the doors are opened and closed.
Since heat rises, the BR A/C in our RV tends to run more steady than the one downstairs.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 08-31-2014, 08:34 PM   #9
Ret E-9 Anchor-clanker
donanddona's Avatar
At sunset I shut the vents at the AC and let the ducting cool the RV. At noonish I open the main Ducts at the AC to prevent the freeze ups. Your on and off modes are normal, keep in mind the AC is designed to cool 10-15 degrees from outside temps.
donanddona is offline   Reply With Quote
Old 08-31-2014, 10:58 PM   #10
Thanks for all the good information. I didn't realize those cycle so often, even at night. I had it set for 72 while even at night it was humid and mid 80's. Run for 90 seconds, off for 90 seconds. . I did not get to move the vent away from the thermostat before we packed up. So that might help.
