A/C unit stays on issue
We have a 2016 XLR Thunderbolt 5th wheel toy hauler, 375AMP. One of the A/C units stays on continuously, even when I change the temp setting higher. It used to cycle off & on once the temp setting has been adjusted. For example, if set at 80, then adjusted to 82 or 84, it would cycle off until the temp in the trailer reached the higher temp, then come back on. Just like an A/C unit in a house. Now the fan runs continuously till it is turned off. Is the issue in the unit itself or in the actual switch/control mechanism? Also, how often should the filter be changed? On the same cycle as for a house or more often?
