Old 05-12-2013, 06:43 AM   #31
Herk7769's Avatar
Originally Posted by VinceU View Post
Heres an update: NJ does have a rule of propane bottles DOT must be closed in transit. This does not speak to ANSI approved tanks with fixed installation and more features. This should answer Herks question about propane vehicles.
Thanks Vince. The pressurized fuel bottles are supposed to be "crushproof."
HAM CALLSIGN - KC3FFW
Old 05-14-2013, 07:38 PM   #32
BillyBass's Avatar
Originally Posted by leadhead358 View Post
This is new to me.
When traveling down the road and wanting to keep the refrigerator cold using LP, do I have to have the 12 volt electric disconnect ON in the trailer to get the ignitor to fire the propane for the fridge or does the tow vehicle being hooked up to it fire the ignitor for the LP on the fridge and the disconnect can be left off.
If you have elec brakes you have to have the disconnect turn on so they will work plus you have to have the battery on to use gas elec ignitor
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 05-14-2013, 07:59 PM   #33
Power for electric brakes comes from the tow vehicle. (Not sure about emergency-disconnect power. I would think that has to bypass the cutoff as well.)
Old 05-15-2013, 08:20 PM   #34
BillyBass's Avatar
I was told when I went to get my trailer inspected before I had to have a battery with the old trailer without the disconnect .When I bought my new one I was told I had to have my disconnect put out when traveling.
2014 14 nites
2015 16 nites
Old 05-15-2013, 08:44 PM   #35
I'm not familiar with your terminology "disconnect put out".
I see that I also used a poor choice of words with "emergency-disconnect". I meant emergency break-away switch (which turns on the brakes if the trailer breaks away from the tow-vehicle).
