04-19-2015, 06:43 PM
AC issues
Setup at the Florida Baptist DR warehouse in Leesburg. My wireless thermometer said 94 inside and out when I arrived. Cranked up the AC and it isn't cooling. It took 2 hrs to get down to 90 by then it was 89 outside... Its been running for nearly 5 hrs and it's at 80 inside... 77 outside. Water is condensing some and dripping off roof; but not as much as u would expect... air temp at the closest register is 71 degrees... I ran it most of the time with the vents bypassed... Opened them up then. The return air filter is 79 degrees. Not much difference... Anyone have an idea??
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
04-19-2015, 06:53 PM
does the compressor run continuously? low voltage could cause it to cycle on and off. has the door stayed closed? its going to pull humidity at first...then cool. if humidity keeps coming in..like getting set up...it may take a while. you should get a 22 degree split in temp
04-19-2015, 06:59 PM
If your seeing condensate run off the roof then I suspect the compressor is on and pulling the moisture out. If it's continuing to run condensate I would wait it out overnight. If you don't see anymore then maybe the compressor quit or it froze up.
04-19-2015, 07:32 PM
8 degree split in temp. Compessor only stopped when I left it off for 15 min then turned back on. Not cycling. No, the doors have been closed all the time... It never (today) put out cold so I don't think it could be frozen. Its now 78 inside and 71 out. I'll be turning it off and using the Maxxair fans tonight ; soon; see how it goes tomorrow. Oh, I have a progressive protector its showing good voltage (118vac), no codes, and pulling abt 13 amps, with only the major appliance; the AC running.
Hyper Lite was sold
04-19-2015, 07:37 PM
Could just be a lot of load from the RV being closed up and so hot initially inside. If you get things cooled down tonight and under control I would see how it does tomorrow. It should have no problems with the cool nights and lower outside temps.
04-19-2015, 08:38 PM
WW there is a fan only mode too on that thermo controller - maybe that's engaged not the Air condition - I ran across this accidentally -
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
04-19-2015, 08:55 PM
If you have a Dometic thermostat, make sure it is in proper mode, It is not the most intuitive operation. Check operating instructions here:
http://www.primetimerv.com/download/...structions.pdf
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-20-2015, 07:43 PM
Thanks for the replies! Didn't get to check it today. But its not hot; a cool front came through. The vents are all I need. I was going to take off the shroud after the work day but it stormed. I have a gut feeling the outside fan isn't running, but won't know until I get on the roof. pH, I don't think I can run fan only. I can run ac fan with the furnace. Thanks flybob for the link.
Hyper Lite was sold
04-20-2015, 07:44 PM
I think your right WW. If it's making condensation, then the pump is running. Likely the fan not distributing the cold air it's making.
04-24-2015, 12:43 AM
WW fix AC yet? ❓
2008 Can Am Spyder
04-24-2015, 06:51 AM
No sir. I'll call RVW today and arrange (hopefully) a repair in Georgia. I'll be there all of May
Hyper Lite was sold
04-24-2015, 07:21 AM
WW
Bummer you have to call for the AC repair. But hopefully it's fixed soon.
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
04-24-2015, 07:32 AM
Time to test out that nationwide service network... Let us know how it works. Haven't had anything I couldn't repair myself yet, but curious how it's handled if necessary.
04-30-2015, 12:31 PM
Camper's Inn came through big time. I now have a new AC unit. They dropped what they were doing on Monday to take a look at it and ordered a new air conditioner ... It came in two days later and today they installed it in about 1 hour. Nice people and great service. This is Camper's Inn Jacksonville just off I-10. Hats off to Gator and Phyllis.
Hyper Lite was sold
04-30-2015, 12:50 PM
WW
Happy to hear the warranty work was completed quickly and to your satisfaction.
06-11-2015, 12:24 PM
seeing a few threads here on new dometic acs. I just got 2 pallets of upper units yesterday. curious if the upper units are the issue or more into the install/electronic controls. hard to get closure on these boards in terms of what is the issue with these...
06-11-2015, 12:40 PM
They (Campers Inn) replaced the upper unit... The Delta was about 7 to 8 degrees.. Compressor and fan ran... Just no cool
Hyper Lite was sold
06-11-2015, 12:47 PM
I feel so much better dealing with Gator since Campers Inn took over. That other yahoo they had as a service manager was a joke.
2014 Salem 30KQBSS
2006 Chevrolet 3500 DRW Duramax EFI by ATP Trucks
Nights Camped 2015-45
Nights Camped 2014-35
06-11-2015, 01:43 PM
X2... The only place to go in Jax... IMNSHO
Hyper Lite was sold
