Your OTR antenna has a booster that's powered ... the plate with the green light ... one of the coax connections is "other" TVs... for me, the coax cables on that output splits and runs to the bedroom and garage TV locations. I don't know if its easier to run to the booster or to an "other" TV location in your TH ... but you will split it where ever and run to the outside weather resistant coax box. For me, I would run from the garage outlet; split it there... drop down the inside wall and run inside the cabinets to the outside box. I would have to see your unit to go into more detail.
WW
welcome to the forum
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
