Old 04-11-2015, 10:21 AM   #1
WolfWhistle's Avatar
air bubble in the Dicor, you should check
Hi everyone. When installing the Maxxair vents yesterday I noticed potential for leaks. The dicor across the front nose to roof connection had air bubbles in 4 places that could cause a leak.
I cleaned them out, cleaned the surface and filled with Dicor sealant. No after pictures, not much to see. I used white and the original was gray.
Name:	Bubbles in Dicor to fix.jpg
ID:	73890   Click image for larger version
Name:	Dicor sealant.jpg
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 04-11-2015, 01:18 PM   #2
geefhoust's Avatar
This is something I will definitely be checking when I get my 30 HDS. I had the same issue when I bought my Mini-Lite in 2011. I also didn't like how uneven the sealant was, kinda like it didn't fill the channel all the way in. I bought the self leveling sealant and filled it in the way I thought it should be. Thanks for the heads up.
2016 Ultra Lite 2905SS
2014 Chevy Silverado 2500HD
geefhoust is offline   Reply With Quote
Old 04-12-2015, 08:56 AM   #3
northstar1960's Avatar
noticed some small spots on mine when i picked it up had the guy doing the walk through fill them in at that time
northstar1960 is offline   Reply With Quote
Old 04-12-2015, 07:30 PM   #4
nice catch. I think this product is prone to bubbling. I think it skins over quickly and traps gases.
Old 04-13-2015, 01:47 PM   #5
Boso's Avatar
Rubber roof
I have had 3 rv's with rubber roofs price range 36000-240000 all had bubbles in the rubber or under the rubber don't effect the warranty normal on Thor and Fleetwood
Boso is offline   Reply With Quote
