Old 07-31-2014, 03:15 PM   #1
Air Conditioner smells
Anybody have issues with air conditioner blowing burnt rubber smell. Doesn't smell with fan running just when ac is running. Looked more simple wiring problems anybody know what I should be looking for. Still brand new and at its first campsite for two months only. Any help appreciated thanks. Tom
cybulskiet is offline   Reply With Quote
Old 07-31-2014, 04:14 PM   #2
VinceU's Avatar
Compressor or wiring overheating? Remove cover and look/feel around.
Old 07-31-2014, 04:40 PM   #3
TURBS's Avatar
How can u get the compressor running without the blower? [emoji101]
TURBS
"SABRE OWNERS UNITED"
Old 07-31-2014, 07:51 PM   #4
Looked around nothing suggests power issue. Everything works cold air fan etc just a bad smell almost like chemical.
Old 07-31-2014, 08:07 PM   #5
WolfWhistle's Avatar
Burning rubber or burning wires? You could get on the roof and take the cover off; have someone inside start the AC and see what you can see. Watch out for the fan... which I have seen an older unit that the fan didn't turn and got hot. I don't think it caused a bad smell, since its on the outside. I would take a quick look, but it sounds to me you need professional help... err... your unit needs professional help. Wolf.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 07-31-2014, 09:42 PM   #6
VinceU's Avatar
Could be contamination in the evap coil, the one inside. Can purchase cleaning compound in spray can (auto A/C) and flush it out. Very common problem in cars when AC laid up cool and full of moisture forms growth and odor. Not sure about chemical smell,
Old 07-31-2014, 09:52 PM   #7
Evereddie's Avatar
I think you are on it. Turbs, what I think OP meant was if the circulating fan is run without running the cooling function it doesn't smell. (Fan circulating air only) When the compressor is activated (by turning on the cool function) there is a smell. If the fan that pulls air through the condenser outside is frozen it would smell. While it should be a separate system, some of that burning smell could get sucked inside. If that motor was frozen,it would not cool as well but that might not be the first thing that is obvious. Run like that too long and it could burn up what is left of that motor.
Evereddie is offline   Reply With Quote
Old 07-31-2014, 10:01 PM   #8
Ya I had it all open and ran it. Everything seemed good no smoke everything turned. Nothing out of the ordinary I'm about ready to let her burn.
Old 07-31-2014, 10:21 PM   #9
Old 08-02-2014, 06:40 AM   #10
I love the smell of napalm in the morning!
Hyper Lite was sold
Old 08-02-2014, 09:48 AM   #11
Evereddie's Avatar
perfect! That's a 10.
Old 10-22-2014, 01:20 PM   #12
blkshp366's Avatar
AC Smells..
Remove filter cover and filter from the ceiling kitchen area.. there is a grey box inside.
Remove the lid to the grey box.. ( Be sure to have all power off / unplugged )..
There may be wires in there burnt.. Mine were cooked..
Took the unit to camping world and they are taking care of the repair.
Hope this helps..
blkshp366 is offline   Reply With Quote
Old 10-28-2014, 08:04 PM   #13
Thanks for the follow up, B! Did they say why wires were melted?
Hyper Lite was sold
Old 11-03-2014, 10:44 AM   #14
blkshp366's Avatar
AC Smells
The tech at camping world said that the original install used a crimp type wire connector and that is was apparently not crimped tight enough.. This allowed the wires to arc sometimes..
They are replacing the entire control board and using a better wire nut this time..
Thank you.
2016 XLR Nitro 305VL5, 2006 Chevy Duramax 4X4 Crew Cab..:trink39
