Old 05-03-2016, 12:27 PM   #11
WolfWhistle's Avatar
Mine does have the black friction material.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 05-03-2016, 02:30 PM   #12
ccsvolsfan's Avatar
I loved my Andersen. It was everything advertised. when it traded for 5er, I bought Andersen Ultimate. Love it also. I have Andersen wd for sale. $350.
ccsvolsfan is offline   Reply With Quote
Old 05-03-2016, 06:27 PM   #13
I really like the Andersen hitch, I converted two years ago and my 1/2 ton Ford pulls real nice with this setup. My first trip using the hitch was over 2,000 miles and I notice a huge difference when passing or being passed by semi's. Plus the fact it seems easier to back into a spot.
Stovebolt is offline   Reply With Quote
Old 05-03-2016, 06:44 PM   #14
How well would the Anderson be for a one ton tv and a th with 1350 to 1450 tw ?
Big Red and 30WR is offline   Reply With Quote
Old 05-03-2016, 06:53 PM   #15
They are rated up to 1400 tw.
Check out their website -
https://www.andersenhitches.com/Cata...ion-hitch.aspx
I love mine and would recommend them to anyone.
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 05-03-2016, 07:03 PM   #16
R3Jones's Avatar
I bought one (an Andersen) for my Nitro 31fqsl and didn't have good luck. Of course I'm pushing the limit of the Andersen. I switched to a Reese dual cam with 1500 lb bars and saw a significant improvement.
Sounds like the hyperlites are running it with good results.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 05-03-2016, 07:37 PM   #17
-R.Jones
Nitro 31FQSL
I got a reese dual cams (old style )hitch with 1500 bars that I`ll try first . Before I spend more money . Have a equalizer 12k 1200 that I think I can do better . Won`t take much to swap hitches out and try the reese first .
Old 05-03-2016, 11:42 PM   #18
Blog: RVroadtripper.com
hbillsmith's Avatar
I towed my Dutchmen Kodiak 242resl behinf my Mercedes GL450 for 3 years about 15,000 miles using my Andersen WDH and it lived up to their no sway name and was a very enjoyable tow. Traded up to a 5er last year and run with the Andersen Ultimate. Still have the old Andersen WDH in a box. Probably will sell it if I get a reasonable offer. I am in Dallas TX.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 05-04-2016, 10:47 AM   #19
DaveSchwartz's Avatar
Originally Posted by northstar1960 View Post
Nope not nearly as bad as those pulling in with the old fashion bar type banging around for hours as they try to back up and un-hook .those not only wake up the campground but also the next campground down the road
Why would someone in the final stages of arrival (campground, driveway) not just get out and loosen the pressure handle? Expecting high winds or a passing semi, are we? Or just enjoy all the groaning and popping?
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 05-04-2016, 02:58 PM   #20
First if its working properly there is no noise unlike nearly all the rest. Not sure what a pressure handle is; but if your talking about "load or sprung or WD" bars (?) The equivalent in an Andersen would be to back off in the tension chain nuts and remove the triangle plate. As you enter the park you would stop in the road and run the tongue jack down to take off the pressure to remove the triangle plate. Leaving a park just the reverse. Same work if I did that on my old Reese DC. I've heard a lot of creaking and popping when others drive in and out. Maybe only a few would be so courteous but it would be a neighborly thing to do. I like the folks with the diesels that fire the up around 4 in the morning and take way too long to hookup; idling noisily the whole time. Far more annoying than an occasional creak.
WW.
hitch
