Old 09-28-2011, 10:43 PM   #1
tlhintoq's Avatar
Send a message via Skype™ to tlhintoq
Any comments or warnings on new 40x12?
We are full timers planning to upgrade from our 2007 FR Sandpiper 37sp toy haul to a 40x12. We want the better bedroom/bath space, kitchen slide for space, 2nd bathroom, L shape kitchen, loft etc.
I was wondering if anyone has any comments or warnings on this model.
I plan to do the winterization package for insulation and dual pane windows, bedroom air con, and garage air con.
I was going to do the washer/dryer until they said 'electric'. That's silly when you have propane but only 50 amps. So I'll do that upgrade myself.
Is there anything else recommended as a must-have or must-do on this?
Recommended dealers? Fun Town RV in Texas seems to have good pricing and make it up in volume. But I read in another thread someone mentioned RVW had there model for 3,000 less with more features. I don't know who RVW is. RV World??? What city?
2011 XLR Thunderbolt toy hauler. 44'5" at 12'2" tall
2011 Ram 3500 dually, 6.7L Cummins turbo diesel
tlhintoq is offline   Reply With Quote
Old 09-28-2011, 11:16 PM   #2
grhodes50's Avatar
They're probably referring to RV Wholesalers.
The Original RVWholesalers, Big Country Fifth Wheel, RV Sales, RV Wholesale Dealers
Gary & Trish
2018 Nights Camped - 5
Old 09-28-2011, 11:50 PM   #3
Dave_Monica's Avatar
By the published specs that toyhauler has a dry pin weight of 2522 lbs and a dry weight of 14554 lbs...these numbers will be understated.
That's a big, heavy camper...hope an upgrade to a 1 T dually is part of the plan.
Dave
Old 09-29-2011, 08:39 AM   #4
tlhintoq's Avatar
The spec weight isn't much more than the spec weight on my current 5er. My Ram isn't dually but handles that quite well.
Old 10-05-2011, 08:41 AM   #5
40x12
I have had for about a month now, the only issue so far has been with the stereo, the outside speakers were hooked up with the sub-woofer, simple process of switching a plug and its fine. The stereo is distorted when playing through an ipod or mp3 player, haven't been able to check into it yet, other than that love it. Try All Season's RV in Michigan, they have early 2012 versions on clearance.(less than 49K) And it pulls very well.
2011 GMC HD Denali 6.6 Duramax
dtrain76 is offline   Reply With Quote
Old 10-05-2011, 12:30 PM   #6
tlhintoq's Avatar
Thanks. I'll give them a call and see if they have a 40x12 or 386x12 with the Arctic Weather package
Old 10-10-2011, 04:38 PM   #7
I've been looking at XLR's for quite a while now. Just can't get a dealer to get where I consider reasonable- either they want to low ball a trade or expect you to pay full list price for the new unit. As far as the 40-12, I would recommend the AMP IT UP package. It gives you Corian countertops and some other minor tweaks- makes the interior really sharp. Another cool option is the pass through rear bed- gives you another place to eat if you want to. And as someone who has actually checked out the weights, I can tell you Forest River is pretty close to what they advertise as dry weight. Just looked at an almost fully loaded 3514 and the actual weight from the factory was 13346. They now have a yellow sticker inside the entrance door with the weight it leaves the factory with all of the options on it. If you find a 40-12, you can ask a salesman to go out and look at the sticker and know exactly what it is. . good luck in your search.
MightyMike is offline   Reply With Quote
Old 10-11-2011, 12:14 AM   #8
tlhintoq's Avatar
We decided to keeping looking, but for a 386x12 because they are 1500 pounds lighter before adding on options.
I'm not sure why yep, but the brochure shows them 3 feet longer yet 1500 pounds lighter. The only major difference I see is the rear toilet. I wouldn't have expected that bit of carpentry to weight that much more than the permanent stairs that goes in it's place. I'll have to keep digging around to see where that weight savings is coming from.
Old 10-11-2011, 04:26 AM   #9
Not sure myself, but I think part of that weight comes from a bigger slideout for the entertainment system. The 40-12 has the Tv/fireplace in the center of the rig, so only the kitchen is on the slide. Looks like the 386 slide is longer, which may add some weight. Don't know if you are willing to travel, but All Seasons rv in Michigan has a leftover 2011 386. Might be worth a look unless you are set on a certain option list. They did come out with some new tricks for 2012, but you gotta pay to play, right?
Old 10-13-2011, 11:30 PM   #10
tlhintoq's Avatar
We decide to go for it. Picking it up Wednesday! The 2011 386x12 that is. I'll be sure to post a complete set of pix, review and comparison to my trade in.
