Old 12-23-2015, 12:44 AM   #11
mark.g's Avatar
Any update on those photos Bob? Thanks!
2016 XLR Thunderbolt 415AMP
-Progressive Industries EMS-HW50C, SteadyFast Stabilizers
2005 Chevrolet Silverado 3500 6.6L Duramax
-Hillsboro Flatbed, Dakota Hills Truck Defender Aluminum Front Bumper, S&B Cold Air Intake, AirLift Load Lifter 5000 Ultimate, VIAIR Medium Duty Onboard Air System,
mark.g is offline   Reply With Quote
Old 12-23-2015, 06:16 AM   #12
I'd send him a PM Mark. He's much better direct than on threads...
Karl4Cat is offline   Reply With Quote
Old 12-23-2015, 07:01 AM   #13
mark.g's Avatar
Ok thanks.
Old 12-23-2015, 07:06 AM   #14
If he sends you a picture or two, post them up!
Old 01-14-2016, 05:39 PM   #15
Originally Posted by Karl4Cat View Post
We've got plenty of height. I've got two Lifeline 6V GPL-4CT's which give me 220AH in mine. You just can't use the battery box covers but it doesn't matter because they are AGM's and don't need the vents. There is actually enough room for 6CT's (300AH) which are even taller but I didn't want the extra expense and charging time.
Karl4Cat, any idea if I will be able to get a pair of Lifeline GPL-L16T in a 380AMP? Getting ready to order on in a couple of weeks and am spec'ing them.
Lifeline Batteries - Marine & RV Deep Cycle Batteries
Jon A is offline   Reply With Quote
Old 01-14-2016, 06:20 PM   #16
If your setup is the same as mine, then yes, they will fit. I just went out and measured. (You owe me. It was friggen cold, icy, and I've already started on the wine for the night... ) From the bottom of the battery box to the bottom of the hydro pump bracket is 17" on the the door side of the rig. (The ODS has no height restriction at all.) Those batteries will be just under 16" so no problem. By the by, the cheapest place I found to order them is Stored Energy Products. Those monsters aren't cheap. Link: GPL-L16T Plan on extended charging times to go along with the extended run times they offer. Great batteries!!
The only thing I'd be careful of is the stock plastic battery boxes. These things are HEAVY. I'd have some metal ones made up to avoid loosing them on the highway.
battery
