Old 11-04-2015, 07:05 AM   #31
jeff64's Avatar
Originally Posted by ezitin View Post
This is a bit off topic. I would like to remove the 20,s on my tt. I want to install a horizontal 30, and use the space to weld a tray for my generator. Any concerns about this kind of move. Seems to be plenty of space under the trailer. thanks
The only concern I would have here is that those lp tanks are designed with that regulator system to see a gaseous state of propane and therefore intended to be in a vertical delivery position. In the applications I can think of (ie. forklifts is what comes to mind) a horizontal delivery position will allow propane in a liquid state to flow but it goes into a spud valve and regulator to get it back to a gaseous state and at the correct W.C. of 11". I'd recommend that you do your homework here
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 11-04-2015, 07:15 AM   #32
OntarioFireFighter's Avatar
We were out for 37 nights this year - From May 1st to mid-October.
We used electric heaters (with LPG furnace to supplement) for the cooler weather; fridge on LPG for travel, electric on site; cooked with LPG.
Used half of one 20 pounder, didn't touch the other.
We do run our BBQ off a separate 20# - we went through about 1 1/2 tanks on it this season...
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 11-04-2015, 07:15 AM   #33
The vast differences is LP use intrigue me. I'm sure we have an engineer on the forum who can put a formula to this, right?
Or as my engineer neighbor says: I will solve a problem you didn't know you had in a way you can't understand.
2014 XLR27HFS
2006 Ford F450 Diesel Dually
2015 Harley Freewheeler Trike (Tara)
2004 Harley Road King Custom (Gemma)
breezyhillfarm is offline   Reply With Quote
Old 11-04-2015, 07:50 AM   #34
Sc00ter's Avatar
The only issue with the 30#tanks is when the hydrostatic date is due. With the 20#ers you simply exchanged them at a store, but nobody I have seen exchanges the 30s. You will have to buy new or have the hydro test done.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 11-05-2015, 10:57 PM   #35
Kilday4's Avatar
Originally Posted by davel1971 View Post
not often. Love the electric fireplace. Makes lots of heat. Use an additional space heater when needed. Always camp where there is electric, and since it's included with site fee, use it all I can
X2. We don't have the fireplace in our HFS27 but with electric space heaters and full hookups the furnace rarely runs. We get our money's worth when plugged in as well.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
Old 11-12-2015, 09:10 AM   #36
I keep coming to the same question and then realize it would be a mistake. I can wonder into any gas station in Michigan and exchange a 20# tank. Never a 30# while I don't recommend that you exchange your new rv tank for a used gas station one it's a great backup. I take my spare gas grill tank from the gas station if I'm cold weather camping. I always have a backup. Less front end load as well.
rocrider50 is offline   Reply With Quote
Old 11-12-2015, 07:35 PM   #37
Thanks! We decided against the 30#s, in part because of the comments here. Also, we remembered that since he's a farrier with a forge and two 20# LP tanks in the bed of his truck, we'd be best served to stick with the 20# tanks on the TH
chrissybird is offline   Reply With Quote
Old 11-12-2015, 07:41 PM   #38
I've been thinking about getting some really long LP lines made and just tapping into a neighbor's tank! 😄
Old 11-12-2015, 08:05 PM   #39
Left Coast
Filled 2 30's today.....$44.09
Old 11-12-2015, 10:13 PM   #40
Play Harder's Avatar
I think I'm going to up to 30 I seem to use a lot more propane to heat than others - don't allways have shore power - the noisy generator drives me crazy --- and maybe because my wife Expects it to at be atleast 70 plus In the RV all winter 😁
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
tank, upgrade
