Old 11-02-2015, 07:59 PM   #1
Anyone upgrade from 20 to 30lb LP tanks
The 29HFS comes with two 20lb tanks. Has anyone felt the need to upgrade to 30lb tanks? Any general sense for how long the 20lb tanks would last with just two people in the RV, who'll probably grill more than cook inside?
chrissybird is offline   Reply With Quote
Old 11-02-2015, 08:27 PM   #2
Kilday4's Avatar
We have the 27HFS and after two camping seasons have used less than 3 full 20lb tanks. Our main use of gas is the water heater, occasional furnace, and fridge on gas during travel. When using full hookups we utilize the electric side of the water heater and also have a supplemental electric space heater for cold nights. Ultimately how often you camp will determine the amount of gas used. We seem to average around 25 nights of camping in a season. Not near enough in my book. Hope this helps.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
Old 11-02-2015, 08:30 PM   #3
Blog: RVroadtripper.com
hbillsmith's Avatar
My 30# tanks last forever, more than a season the way I travel. I actually thought about sizing down to save payload.
hbillsmith is offline   Reply With Quote
Old 11-02-2015, 08:30 PM   #4
Very helpful, thanks!
Old 11-02-2015, 09:15 PM   #5
John513
JohnRiordan's Avatar
Mine last a longtime when just using water heater. If you use in cold weather with furnace in say 50s at night then a tank will last me around 4 days and if it gets down in 30s I can burn through a tank in 2 days.
JohnRiordan is offline   Reply With Quote
Old 11-02-2015, 09:17 PM   #6
John513
I am seriously thinking of upgrading to 30, but I have like 5 20lbsers laying around.
Old 11-02-2015, 09:38 PM   #7
TURBS's Avatar
My new 320rs has 3 20 lb tanks vs 2 30's I like it much better.
I bought a propane tank base stabilizer and keep a spare in the front cubby.
Easier to handle.
Easier to exchange.
More convenient!
I got 80 lbs on board.
Old 11-03-2015, 03:38 AM   #8
mud yapster's Avatar
Our Palomino has 3 20# and I just alternate using 2 of them and when I have to turn on the 3rd one I refill the other 2. I like my tank set up and they last a good amount of time. On one tank used the fridge on propane while travelling 16 hours and then used the same tank to cook with for 5 days and still wasn't empty. I'm sure if running the central heat it would burn a 20# tank up quickly in 2 days. 20# tanks hold 5 gallons and 30# tanks hold 7.5 gallons so having 2 30# tanks is equivalent of 3 20# tanks.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-03-2015, 05:50 AM   #9
davel1971's Avatar
I haven't used 1 tank yet in the 2 years I've had this 5th wheel. Over 80 nights spent in it. Several thousand miles of traveling with fridge on propane.
David & Lynn
Old 11-03-2015, 06:20 AM   #10
jeff64's Avatar
If I had 2-20s, I wouldn't upgrade to 2-30s just because. Price a new 30# tank out empty, you would be hard pressed to find one under $75. I probably burn 40# a year anyway. Just not a big deal for me
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
tank, upgrade
