Old 05-22-2015, 04:32 PM   #1
Thekipkers's Avatar
Auto level help needed quick
My folks have the hydraulic auto level on their xlr fiver. Trying to get the rear jacks up and no matter which button he presses they continue to go down.... Any ideas
SK2 CAMPING CREW
2010 Ford F-350
2015 Wildwood XLite 262BHXL
Thekipkers is offline   Reply With Quote
Old 05-22-2015, 10:41 PM   #2
textman's Avatar
should be able to go into manual mode and then push the retract button before pushing the front side or back button... that is if it is like mine... good luck
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 05-24-2015, 07:21 AM   #3
XLR Production
Make sure you are pressing the retract button
bulletbob is offline   Reply With Quote
Old 05-24-2015, 08:55 PM   #4
Agree make sure retract button is push, mine has a little light that tells u when retract is on.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 05-25-2015, 11:58 AM   #5
Auto Level
I had our jacks extended on the left side to level up the trailer (Cardnal 3800FL) on our street. When I went to retract them it signaled excessive angle when pressing the left button with the retract on. I finally got them to retract by pressing the rear button with the retract on. There must be a sensor that stops the jacks if the system senses there is an excessive angle on the trailer.
Reason201 is offline   Reply With Quote
Old 05-25-2015, 12:58 PM   #6
On ours you simply turn on the system, select manual mode, push the retract button (ours has an amber light to indicate that it is in the retract mode) and then push the rear button. If the system is working correctly this should do it. Good luck.
Learn from the mistakes of others.....you won't live long enough to make them all yourself.
Cheers &
Flatlander
2015 Silverback 29IK
2010 Silverado 2500HD LTZ
6.6 Duramax / Allison 1000
Flatlander49 is offline   Reply With Quote
Old 05-25-2015, 03:55 PM   #7
Love RVing
I agree "Retract". Just got a Cedar Creek 36CKTS and was having trouble being out of level using Auto level. Called Lippert and they told me how to recalibrate the computer. They are online at lci1.c o m also
burse is offline   Reply With Quote
