Old 03-23-2013, 12:43 PM   #1
Automatic LP regulator changover
I have searched and read a lot about the automatic changeover of the lp dual tanks but still have some doubts that I know how this works. Could someone tell me what brand I have on my 2012 HFS and How it works? I am going to try and post a picture of it. I has the orange and green dots. I am confused about whether or not I am supposed to manually turn this thing or if it does it automatically. We asked the guy filling the tanks at Pilot and he turned it back and forth several times before he advised that he was not sure how it worked
Name:	automatic changeover regulator 1.jpg
2012 XLR Hyperlite 27HFS
2010 Ford F250
2010 Harley-Davidson Softail Custom
kathys85 is offline   Reply With Quote
Old 03-23-2013, 12:46 PM   #2
wyo700's Avatar
I was told it only ran on the tank that has the green dot and it had to be manually changed that it wouldn't do it automatically.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 03-23-2013, 12:52 PM   #3
I know that it will actually automatically switch over to the other tank. It has been doing that, but just dont know if I have to manually turn the dial for the colors to reflect that.
2010 Ford F250
Old 03-23-2013, 12:53 PM   #4
B47
We were told that it functions as it's name implies - when one tank is empty, it automatically switches to the other tank, assuming the tank is full.
The dots show which tank is full (green) or empty (red/orange).
FWIW - either we didn't understand how it works or it didn't work the first time one of our tanks went empty and we found that both tanks were empty.
The dealer installed a new one and we have not yet emptied a tank, so we are not sure it works or not.
B47 is online now   Reply With Quote
Old 03-23-2013, 12:54 PM   #5
I just have not been paying close enough attention to the green and orange dots during operation. We have only refilled them twice and refilled them both at the same time?
2010 Ford F250
Old 03-23-2013, 12:56 PM   #6
B47 when you refilled the tank, did you manually turn the dial to one tank of the other?
2010 Ford F250
Old 03-23-2013, 12:58 PM   #7
B47
Yes and that is the last time I have touched it.
Old 03-23-2013, 01:03 PM   #8
Denver, CO
garbonz's Avatar
It switches from one to the other automatically and the red dot lets you know that. Thus, you know to fill the empty one. At that point switch the valve and get the empty one filled. My experience has been to turn both tanks OFF when you remove the empty one to get it filled, or you get a little seepage from the line that is disconnected.
2017 Fuse 23T
Old 03-23-2013, 01:06 PM   #9
OK that makes sense. I think I have wrapped my head around it. I guess they thought it was so easy we did not need the user info on it.
2010 Ford F250
Old 03-23-2013, 01:10 PM   #10
64c10's Avatar
OP, your pic appears to be the 924N automatic changeover regulator.
the dots tell witch tank is being used. 2 green dots show primary tank, 2 red dots show that tank 1 is empty and regulator has changed to tank 2. you can change dial to show 2 green dots, thus starting the process over. now that we are all confused , the web site for the regulator is cavagnagroup.com
2012 A122BH
TV1 2006 Honda Ridgeline
TV2 2014 Chevy 1500 Silverado Crew cab
64c10 is offline   Reply With Quote
