Old 04-01-2015, 08:36 AM   #11
Plug32's Avatar
Look at it straight on. The U channel should fit in the track. We have to push ours to the rear to get the channel to close. It is an 1/8 inch off. The U channel main arm just misses the flat channel that runs vertical,flat against the coach. See if it is a hair off.
2014 Forest River
XLR Viper
305V12
Plug32 is offline   Reply With Quote
Old 04-01-2015, 08:40 AM   #12
TURBS's Avatar
Your awning fabric has moved on your roller.
Unroll awning then slide the fabric one way or the other so it rolls up like it should then put a screw threw the fabric into the roller so that it doesn't move.
TURBS
08 duramax tuned n modded, 32bhok Sabre
Old 04-01-2015, 10:36 AM   #13
Plug32's Avatar
Thanks!! I'll give it a try..
2014 Forest River
XLR Viper
305V12
Old 04-01-2015, 01:27 PM   #14
bubbles's Avatar
Originally Posted by bubbles View Post
That is not correctly installed. I think screws and caulking is what secures mine flat against the unit.
Guess I spoke out of ignorance. However; mine is flat against the side of the unit with a foam strip the length of the rails that take up any minute space that there might be. Thought it was caulking.
bubbles is online now   Reply With Quote
Old 04-02-2015, 05:29 PM   #15
WolfWhistle's Avatar
mine is flat against the wall; top to bottom and sealed along the edges with black silicone from the factory
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
awning
