Old 05-01-2014, 06:50 PM   #11
@ Scooter86 - my awning LED lights on my 29 is wired the same as yours - it is stupid - so there must be a remedy!
Duke and Bren
Pensacola, Florida, USA
Retired
2015 XLR 29HFS HyperLite TH
2006 Chevy 2500HD Ext Cab
Dukester is offline   Reply With Quote
Old 05-01-2014, 10:29 PM   #12
10x
Seems like a factory screw up?
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 05-02-2014, 07:38 AM   #13
Definitely am of the opinion that that is the case (factory defect). I am making a list of things that need to be "fixed" on mine to include the piece of crap support stands that fell apart on my built-in dinette in the garage. Several factory install adjustments need to be done. But, let me make myself very clear: I (we) am (are) VERY pleased with the 29HFS XLR TH. Overall it is a magnificent piece of equipment and I anticipate many years of enjoyment. The trip down to Florida from Ohio (Franklin is where I picked it up) was uneventful and it pulled like a champ. Very pleased. Oh - and our virgin camping stay was at Seven Points Campground in Heritage TN just east of Nashville of I-40. This is a Corps of Engineers Park - Hey! Do yourself a favor if you're in the area. Very nice park and very nice managers...
Oh - we have dubbed our trailer "Valhalla"...
Duke and Bren
Retired
Old 05-02-2014, 07:46 AM   #14
I haven't had the opportunity to dig into it yet, but it is probably the actual switch they are using since it effects multiple units. I wonder how hard it will be to find a new switch for it? Also, I agree, love the unit. We have only camped in the driveway so far. We had a brake wire severed at delivery, dealer fixed same day. The only other issue so far besides that switch is the speakers are wired a bit wonky. Everything works, just maybe not the way I would prefer.
Scooter86 is offline   Reply With Quote
Old 05-02-2014, 08:20 AM   #15
So, it's not just a matter of re-routing the wiring on the light switch panel by the front door? Definitely sounds like a factory problem to me...looking forward to seeing what you come up with!
Duke and Bren
Retired
Old 05-02-2014, 09:44 AM   #16
If there is more than one switch at the location then it can be fixed. Pull the switches out of the wall and you have to get a constant hot wire to the line side of the led switch.
Problem solved
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-02-2014, 10:02 AM   #17
mark0224's Avatar
Had to add my awning lights so did wiring myself, but it should be an easy fix determine which wires of the switch go to the inside lights and add another switch to cover them.
mark0224 is offline   Reply With Quote
Old 05-02-2014, 11:16 AM   #18
In my previous trailer, I had multiple ceiling lights working off a master wall switch and each individual light had it's own controlling switch on the light fixture itself. Not the case here. We have three switches on the wall or cabinet panel by the front door. 1st one controls inside lights, next one the porch light and the 3rd one is the LED lights on the awning. The way it is wired (or, at least mine is), the switch controlling the interior light has to be on for the outside lights to work. I'm thinking R Whitlow is absolutely right. It's just a matter of re-routing the wiring scheme on the three wall switches.
Duke and Bren
Retired
Old 05-02-2014, 06:58 PM   #19
Good news! The issue is a fairly easy to fix mix up at the factory. There are 2 orange and white/white wires on my unit at this fixture. One is hot from the power supply, the other is from the ceiling lights. The power on my unit is connected directly to a switch. It should have gone into the connection that has 3 more wires, each connected to its' own switch to supply the power(as R Whitlow mentioned above.) Switching the wires will make everything work as it was intended. All it will cost you is about 10 minutes and a few new connectors. Not worth the fuel to swing it by the dealers for me.
In the first photo I am holding the crimp connector with the offending party.
The second image shows both orange/white wires that will need to be switched.
ID:	51458   Click image for larger version
Old 05-02-2014, 07:10 PM   #20
Hah, took me longer to attach the pics than to fix the switch. I need to go adjust my link-fu, (or at least read the forum directions again!)
awning, led
