Old 06-06-2015, 08:07 AM   #11
Mine was the same way when i picked it up. Had to rewire switches andnow works fine.
stefan is offline   Reply With Quote
Old 06-07-2015, 09:11 AM   #12
WolfWhistle's Avatar
Simple fix like Bulletbob describes. They simply connected wires wrong to the switches, and are feeding 12 volt to the awning light switch from the interior light switch rather from a clean B+ fed. Easy access by popping of the switch cover and removing a few screws; then pulling out the wires to gain access.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
WolfWhistle is online now   Reply With Quote
Old 06-07-2015, 09:51 AM   #13
Evereddie's Avatar
Originally Posted by laurajean View Post
Mine had that problem and my friends an electrician helped me reconfigure it, but afterwards the led strip does not light up as fast as it did. The strip sometimes has dark dpots, but after awhile they all light up. Not sure why that happened. I ended up only changing two leads and their position. Now each switch is independent.
There have been a lot of failures of the LED strips put on trailer for a year or so. What you describe is how they start to fail. Lower voltage can make this look worse so maybe the new connection you made doesn't have as much power. Also could just be bad timing and this was about to happen anyway. Search this forum for LED awning strips and you should find many threads about the failing lights.
Evereddie is online now   Reply With Quote
Old 06-22-2015, 12:36 PM   #14
My 2014 305v12 xlr is the same way
JimKin is offline   Reply With Quote
awning, light
