Old 06-02-2015, 09:17 PM   #1
Awning light strip
On our 2015 xlr29hfs, the light strip under the power awning will only switch on when the switch for the main living area light is on. is this correct? Or is there a mix up in the wiring?
SaskJade is offline   Reply With Quote
Old 06-02-2015, 09:57 PM   #2
ov845's Avatar
Sounds like a mix up. We have 2015 Windjammer 2809 and ours has a separate switch that operates it.
ov845 is offline   Reply With Quote
Old 06-03-2015, 04:57 AM   #3
My 2015 led light strip works by itself. Yours must have wire issue
2015 29 hfs / 06 gmc 2500hd
lonb is offline   Reply With Quote
Old 06-03-2015, 07:37 AM   #4
InTheSticks's Avatar
Someone else recently posted the same issue, seems there was a misswire issue. I think they were able to pull the switches off the wall and find the wire.
2013 F150 FX4 Crew Cab Lux Package
2013 Forest River XLR 27HFS
InTheSticks is offline   Reply With Quote
Old 06-03-2015, 07:43 AM   #5
John513
JohnRiordan's Avatar
Have not had this problem, but look under cabinet and in screw the corner panel pieces to access the back of the switches. The use one main power wire and jumper across switches. I'm guessing they jumped from from wrong side of living room switch. Move wire that is jumped across switches to the otherside of living room switch and that should take care of it.
JohnRiordan is offline   Reply With Quote
Old 06-03-2015, 07:44 AM   #6
John513
Sorry, unscrew not in screw
Old 06-04-2015, 12:12 PM   #7
Mine is the same. Its irritating. What's the fix?
rocrider50 is offline   Reply With Quote
Old 06-05-2015, 11:54 AM   #8
XLR Production
Pull the switches and you will/should find two orange wires. One being a jumper wire between the switches and one with a blue terminal. It sounds like those two are reversed. Make the one with the blue terminal the jumper wire between the switches and the one that WAS jumping between the switches, make that one the one with the terminal. Now that I have you thoroughly confused, give it a try and let me know
bulletbob is offline   Reply With Quote
Old 06-05-2015, 05:28 PM   #9
Mine had that problem and my friends an electrician helped me reconfigure it, but afterwards the led strip does not light up as fast as it did. The strip sometimes has dark dpots, but after awhile they all light up. Not sure why that happened. I ended up only changing two leads and their position. Now each switch is independent.
laurajean is offline   Reply With Quote
Old 06-05-2015, 07:58 PM   #10
Thank you for the replies. We will look at the wires the next time we camp.
awning, light
