Old 08-11-2015, 06:14 PM   #1
WolfWhistle's Avatar
awning out of adjustment?
I tried searching for "awning adjustment" but the search function on the forum doesn't let you drill down. Maybe its just me not knowing the tool.
Anyway, when I awning is coming in, all it good at first, at half to 3/4 of the way in you can see a diagonal wrinkle start to form in the material. Plus, the motor really slows down. On shore power or fully charged batteries, all the same. Also, as it closes up (or tries to) the vertical arms at the top (near the motor) that should fit around or over the inside arm doesn't.
I should attach a picture, but its under the canopy and I can't open the awning.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 08-11-2015, 06:17 PM   #2
Extend the awning and center it on the tube and pop rivet thru both side hems to keep it centered.
Old 08-11-2015, 06:24 PM   #3
Also check that the material is centered between the arms directly on the trailer.
Mine was of 3/4" and acting a little like you mentioned.
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 08-11-2015, 06:30 PM   #4
by both side hems, are you talking about at both ends?
Thanks OC and Black
Old 08-11-2015, 06:34 PM   #5
Thanks OC and Black
Yes, both ends of the tube.
Old 08-12-2015, 11:14 AM   #6
Awning fabric is stretched, have fabric replaced.
Docgeo is offline   Reply With Quote
Old 08-12-2015, 11:25 AM   #7
Brother Les's Avatar
Check you 'auto dump' arms. Make sure that the 'sliding' part is pushed all the way out on both sides.
Brother Les
Old 08-12-2015, 01:41 PM   #8
Boso's Avatar
Awning
Had one on Rv that did that service tech fixed without much difficulty charged 1/2 hour labor which Fleetwood paid for
Boso is offline   Reply With Quote
Old 08-12-2015, 03:15 PM   #9
Bro Les, yes it is, Tanks!
Old 08-12-2015, 03:21 PM   #10
Pictures one shows arm not overlapping the inner arm; the other shows wrinkles. I think OC has it fingered out.
ID:	85444   Click image for larger version
ID:	85445   Click image for larger version
awning
