Old 07-26-2015, 04:27 PM   #1
battery disconnect will not power up
I don't have power to the camper after plugging in the battery disconnect. I have confirmed the battery is fully charged. Is there a "fuse" for the battery disconnect? it was working just fine on Friday when I put the camper in storage. Went to pick it up today and I had no power.
Thank you for any suggestions you have.
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 07-26-2015, 05:14 PM   #2
Do you have power on the outlet side of the disconnect?
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-26-2015, 05:28 PM   #3
Did not have power for any of the lights inside the canper or power to the tongue jack. The battery meter on the control panel in the bathroom was all dark. I assume it's the disconnect switch but I'm hoping there is reset some place.
Old 07-26-2015, 06:14 PM   #4
Mainous's Avatar
There are breakers on the underside of the electrical buss where the battery cables connect. Plugging your power to your TV should get you power to the tongue jack.
Thanks,
Jeff
-2016 XLR Nitro 31 FQSL
-2006 Chev Silverado 2500HD Duramax LBZ
Mainous is offline   Reply With Quote
Old 07-26-2015, 07:11 PM   #5
Plugging in the TV still did not get me power to the tongue jack. So I brought along the generator to the storage lot. With the generator I have power to tongue jack and all the lights/fans in the camper.
I will look around the electrical buss for any breakers.
Thank you for all the suggestions
Old 07-26-2015, 07:17 PM   #6
Herr is a picture of my electrical buss. On the left you can see my postive feed. There is a little black button that seems to be spring loaded but does not really feel like a breaker.
Thoughts on the picture?
Old 07-26-2015, 07:21 PM   #7
Well, I'm not sure if it was the little black button on the postive feed or hooking up the generator. But I have power thru the disconnect again.
I really appreciate the quick responses and suggestions. Have a great evening.
Old 07-26-2015, 07:35 PM   #8
northstar1960's Avatar
That little black button is a breaker /reset . good to know it's their . had that problem a few months ago and the neighbor found it for me
northstar1960 is offline   Reply With Quote
Old 07-26-2015, 08:18 PM   #9
Well now that I know the little black button is a breaker/reset. I will save this information in my "knowledge vault" for future reference. J
ust so happy everything is back to normal again. Leaving for Sturgis in a couple of days.
Old 07-26-2015, 09:32 PM   #10
Mainous's Avatar
Glad it was that simple. Still concerned that you didn't have power at the tongue jack with your TV hooked up. You may want to check the fuse on the TV cause it should be there.
Jeff
battery, battery disconnect, power
