Old 09-20-2014, 01:01 PM   #1
Bearing greasing
I am greasing the axles for the first time. I pumped 6 pumps per wheel, ( small cartridge gun) I heard it oozing so I did not want to go anymore. Where would I have heard of ooz from? , hopefully not from
ibearingnside brake area. Anyone comment?
laurajean is offline   Reply With Quote
Old 09-20-2014, 01:09 PM   #2
Witch Doctor's Avatar
Maybe just a grease void. Did grease come out around the zerk fitting? They do not come full from the factory.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-20-2014, 03:36 PM   #3
Nothing came pit the zero
Nothing came out the zerk
Old 09-20-2014, 04:02 PM   #4
DDC
DDC's Avatar
I used two tubes the first time I did mine and that was with a normal sized grease gun.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-20-2014, 07:26 PM   #5
WolfWhistle's Avatar
Pump it until you see it coming out around the bearing.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 09-20-2014, 08:12 PM   #6
Where should I see the grease on the bearing, inboard or outboard? I took the cap off the center of the wheel, just inside of that was a rubber stopper, which I removed and then under the stopper was the zerk fitting. Is there any chance of blowing out anything if I put in too much?
Old 09-20-2014, 08:27 PM   #7
Windywest's Avatar
Here's another thread with the same issues, and some good info on the subject,
Lippert axle with EZ-lube wheel bearings?
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 09-20-2014, 08:28 PM   #8
Yes/no. If your rear seals are good and you HAND pump grease in VERY SLOWLY, the grease should come out around the outboard bearing and zerk fitting.
Old 09-20-2014, 08:34 PM   #9
The more I read here about these axles the more I think the best thing to do is just like you do the ones without the zerk fitting. Just check them about once a year by taking them off and don't pump in grease at all.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 09-20-2014, 08:39 PM   #10
indybp57's Avatar
X2. But it takes a lot of grease the first time because you are filling the void in the hub between the inboard and outboard bearings.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
