Old 10-15-2015, 04:14 PM   #21
The Big Toe's Avatar
Paint it. Unless it's that flimsy stuff that likes to bend all over the place. If it's rigid.... Paint it.
Had a car with that problem. I live in Florida so I know what you're going through. Every black piece of plastic down here turns gray after a few years. More like months
Paint it.
Use a 'Matte Black' or something like that. Maybe even a flat black.
Preparation is the key. Remove the pieces if you can, clean them up REALLY well to get that other goop off of it (if it isn't too late already) then prime it and paint it.
You can use a a spray can. It works.
I don't remember exactly what I used.... Plastikote(???).
http://www.amazon.com/PlastiKote-469.../dp/B0007OWD0Y
Found this: http://www.amazon.com/Rust-Oleum-Aut...0_SR160%2C160_
It was so many years ago, I just don't remember. Any paint store should be able to bring you up to date.
If you can't remove the pieces you want to restore, be careful not to get over-spray on everything. Some neighbors have no sense of humor at all
The Big Toe is offline   Reply With Quote
Old 10-15-2015, 09:06 PM   #22
northstar1960's Avatar
Originally Posted by F350TH View Post
I've never had look with back to black at all.
Wipe New however works great, and lasts a long time.
Yes it does , worth the small price
northstar1960 is offline   Reply With Quote
Old 10-16-2015, 07:20 AM   #23
WolfWhistle's Avatar
Paint it.
Amazon.com: PlastiKote 469 Plastic Primer Enamel - 12 Oz.: Automotive
TBT, Back to Black worked fairly well on the fenders, but on the LPG cover, I painted it. I had some left over plastic adhesion promoter and used Krylon plastic paint in a semi-gloss black. Only time will tell how long it holds up. My nearest neighbor is 1000 ft away, so no small claims court, but better not get any on the wife's stuff!!!
Thanks,
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
WolfWhistle is online now   Reply With Quote
Old 10-16-2015, 07:28 AM   #24
Kenny kustom's Avatar
Originally Posted by khocke View Post
Mother's Back to Black
Works 'just OK' on my Wrangler fenders/bumpers & cheaper/easier to find than 303 (which is my go-to slide seal juice)
I use the blow torch method.
Or a good heat gun. Melts the top layer just enough to turn it black.
Works very well.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 10-16-2015, 08:03 AM   #25
jeff64's Avatar
Mother's makes a product called "Back to Black" its a liquid like armorall
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-16-2015, 08:10 AM   #26
TURBS's Avatar
Use this to!
TURBS
08 duramax tuned n modded
2015 columbus 320RS
2015 camping "30 nights"
Old 10-16-2015, 09:42 AM   #27
Kenny Kustom - just checking to see if your recommendation was serious? Kinda hard to tell via written word. If so, I am impressed that you had the guts to try it. Any before/after photos????
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 10-16-2015, 10:57 AM   #28
Left Coast
Automotive paint store here has an aerosol spray paint that's formulated for plastic trim...used it and love it.
Old 10-19-2015, 03:10 PM   #29
New wipe works ok.
rocrider50 is offline   Reply With Quote
Old 10-20-2015, 07:24 AM   #30
100% tried and tested.
I try to find some pics, or a sample
To do a video on.
It works. Just be careful.
2008 F350 CCSB V10
2016 Sabre 36QBOK
black
