Old 07-31-2014, 07:30 PM   #11
davel1971's Avatar
nothing you can do but trace the line to make sure its not kinked. If not, its plugged with something or the flush valve itself is bad or not installed properly. Or take it in for warranty
David & Lynn
Old 07-31-2014, 07:31 PM   #12
Ford Idaho's Avatar
Originally Posted by davel1971 View Post
I think we are fixing a flush problem, not a drain problem Aren't we?
Yep and if the dried up stuff in the tank is going to get "flushed" out in needs to be "rehydrated" and broke loose could be why there is no water coming out, plugged drain?
Old 07-31-2014, 07:33 PM   #13
I will take it in thanks for all the help
2014 29hfs XLR
2008 Ford F250 6.4 PSD
deleted and Tuned
2012 Polaris ranger 800 XP Walker Evans
turbosi44 is offline   Reply With Quote
Old 07-31-2014, 07:39 PM   #14
davel1971's Avatar
ok, so what is really happening. Is nothing coming out when you attempt to drain the tank or is the black tank flush not squirting into the tank? Think we are a little unsure. Just want to make sure we give accurate advice
David & Lynn
Old 07-31-2014, 07:43 PM   #15
Not squirting into tank
2014 29hfs XLR
deleted and Tuned
Old 07-31-2014, 07:47 PM   #16
davel1971's Avatar
is the line accessible to trace or is it all hidden? Don't mess with it to much and risk dealer not fixing it under warranty if it comes to that
David & Lynn
Old 08-01-2014, 01:11 PM   #17
I think there is a check valve in line and it could be installed backwards.
the.wilsons is offline   Reply With Quote
Old 08-04-2014, 06:50 PM   #18
2014 XLR 27HFS
I have the exact same issue with a new 27HFS. I hook up a hose and turn the water on, but no water ever goes into the tank. I had a smell issue early on and have done the ice trick a few times. I've also filled and flushed it many times with all sorts of chemicals. I'm hoping it's not 'stuff' stuck to the flush inside the tank. I plan on getting under it and trying to follow the line from the tank up. If I find nothing, I'll brave taking it off the tank.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 08-04-2014, 07:16 PM   #19
DaGrinch's Avatar
For your "smell issue", I think I'd check this thread first, especially if you have a model 300 Dometic toilet!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 08-04-2014, 07:21 PM   #20
Buddy Duncan's Avatar
I had an issue with my dump, only slightly different. When I used it water came out from below the bathroom sink. I followed the hose and discovered a back siphon unit up below the sink, (higher than the tank). One of the connection nuts was loose. A quick tighten and problem solved. What I did notice was this siphon unit is directional, so perhaps yours is in backwards and acting as a check valve.
Dane & Candice
2012 Sierra
2014 Rockwood 8265ws
Buddy Duncan is offline   Reply With Quote
black, black tank, black tank flush, tank
