Old 02-12-2015, 06:40 AM   #11
Witch Doctor's Avatar
Originally Posted by rfregia View Post
When i hook up the water and turn it on the water hose pressures up. I let it run for about 5 minutes and when i opened the black tank drain nothing came out of it. I will have it back at the dealer next week to fix some other issues i have found I will add this to my list.
Thanks for the help.
Good Idea, when you use your black tank flush you can here it working at the toilet. If not you have a bad valve or a kink in the line. The line is made out of hose material not plex, so it can kink.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 02-12-2015, 06:52 AM   #12
sail2liv's Avatar
We have a hose that we only use for black tank....it has no pressure regulator like the fresh water hose that is for fresh water only....we get full faucet pressure into the black tank, so is important to have drain open in case roof vent is stopped up some...
if no leaks in system water should come out vent on roof...and we sure do not want that if we forget to open the main drain.....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 02-12-2015, 07:30 AM   #13
rattleNsmoke's Avatar
Crawl under your sink cabinet with a flashlight and look up for the valve. If it's clear, this should work.... Have a helper turn on the black tank flush and watch for water flow up into the valve. If working properly you'll see the water rush into it closing the spring assisted flapper, then run out the other end down into your black tank.
rattleNsmoke is offline   Reply With Quote
Old 04-05-2015, 10:44 AM   #14
My check valve was under bathroom sink and installed backwards from factory, I was able to take it apart and turn it around and all is well, good luck!
Billcincaelynn is offline   Reply With Quote
Old 04-08-2015, 05:14 AM   #15
I have the same problem with new 340x12. No flushing noise, no water out the waste hose.
Doreen & John
2015 XLR Thunderbolt 340x12HP
2015 F350 Lariat SC SB 4x4 6.7 SRW
2012 HD Ultra Classic
MN John is offline   Reply With Quote
Old 04-08-2015, 05:50 AM   #16
sounds like the check valve is installed backwards or faulty, very easy fix although I'm not sure where yours is located, maybe under your bathroom sink, it has a water line in and water line out, just unscrew both and turn it around and reinstall,, good luck
Old 04-08-2015, 11:52 AM   #17
XLR Production
It's probably the vacuum breaker in the bath lav. We had a rash of them that were made wring
bulletbob is offline   Reply With Quote
Old 04-08-2015, 12:09 PM   #18
So should I remove, 180 it, and reconnect just in case it's installed wrong?
Doreen & John
Old 04-08-2015, 02:18 PM   #19
XLR Production
I'm guessing that it is another one made wrong. You can try if you like.
Old 04-08-2015, 02:40 PM   #20
Can or will you explain what good they are in the first place?
black, black water, water
