Old 04-09-2015, 01:33 PM   #41
Witch Doctor's Avatar
Originally Posted by OldCoot View Post
My city water & black tank flush BOTH have back flow preventers just inside the trailer behind the hose connection. There is not freshwater back flow preventer as it is a "stick the hose in" type fill with a vent to the side. Anyone need pictures?
That can be true i do not doubt you, but you have a flagstaff and not a rockwood. I have been inside mine more then I ever wanted to and I can guarantee it is not the same, but what ever is? Maybe that is why flagstaffs cost more? More bells and whistles. There is no back flow preventers connected between the pump and the connections to the Water Pump or the the black water flush system. Just the vacuum brake behind the shower handles for the flush system.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-09-2015, 06:39 PM   #42
Originally Posted by MN John View Post
Only 15 miles from home, so if the furnace, my long Johns, and or my wife all fail meÖitís a short trip home! Looking forward to it rebounding to the mid-60s on Saturday.
MN John
You may need a snow plow on your TV for your camping this weekend.
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 04-09-2015, 07:01 PM   #43
I don't have a separate backflow preventer on the pump other than what is built into the pump itself, just the city water and black tank flush.
Old 04-09-2015, 07:21 PM   #44
Steve, I know! What's up with this weather...snowing! We are packing up the RV tonight, even the food and beer coolers...figure they won't lose much ice by tomorrow night with the current temp!
Doreen & John
2015 XLR Thunderbolt 340x12HP
2015 F350 Lariat SC SB 4x4 6.7 SRW
2012 HD Ultra Classic
MN John is offline   Reply With Quote
Old 04-09-2015, 07:25 PM   #45
Nice!
Doreen & John
Old 05-03-2015, 10:14 PM   #46
Gbart's Avatar
Originally Posted by bulletbob View Post
The check valve is located in the bath lav. We ran into a rash of bad ones. Your dealer should be able to replace that for you
How would you determine its bad, Is it normal for the check valve to make a buzzing sound. We finally pick our nitro fifth wheel up on Friday and when I hooked up the hose to the flush I could hear a buzzing from inside. Found under sink, both lines felt cold, so I think water was making it through, it felt wet so I tightened the connections a little. Water does come out main dumping valve. I put my ear to the underbelly of the coach and only could hear a little water trickle noise.
I just posted about a leaky black water valve also. Hope bobs reads this he seems to have a lot of answers
Gbart is offline   Reply With Quote
Old 05-04-2015, 06:02 AM   #47
rattleNsmoke's Avatar
The check valve would be bad if it failed and spewed water all over the floor of your lav cabinet. Buzzing only means the check valve inside is jumping around against it's seat and doing it's job. I wouldn't worry about that. Mine is clear and I can watch it in action. I also had to replace a faulty one that stuck closed.
rattleNsmoke is offline   Reply With Quote
Old 05-04-2015, 06:26 AM   #48
I have the same problem in our XLR 27, the back flow is in the entertainment center behind access panel. It was installed correctly so I took it out and found it defective.
I bought a new one and I am waiting for it to arrive. Although I didn't buy the same one that was there because it was way over priced $50 for that plastic fitting. I found another one online very similar for less than 1/2 of that.
Berjr1 is offline   Reply With Quote
Old 05-04-2015, 06:39 AM   #49
And that would be 'entertaining' to have that compartment flood out.
Old 05-04-2015, 06:41 AM   #50
Gbart's Avatar
I'm gonna hope I don't have that entertainment anytime soon or ever. Thank you everyone looks like mines fine I appreciate it, we had a gearbox before and that one didn't have any type of valve in it and you could hear it inside the tank spraying around just different and new to us.
black, black water, water
