Old 02-10-2015, 10:11 AM   #1
Black water flush
I have a new XLR 340x12hp when i hook up my water hose to the black water flush nothing happens. Does it have a valve on the inlet side that needs to be opened in order for the flush system to work?
Tow rig: 2014 Ram 3500 CC
Old TH: 2007 376srv wildwood sport
New TH: 2014 340X12HP
rfregia is offline   Reply With Quote
Old 02-10-2015, 10:37 AM   #2
My XLR27HFS does not. Hook up the hose and turn it on.
breezyhillfarm is offline   Reply With Quote
Old 02-10-2015, 01:02 PM   #3
Could be a check valve problem, it might be stuck. Try taking the screen off and push it the plastic tab. Just make sure you stand off to the side when you push it in. The pic is of a regular fresh water connection but gives you an idea of what to look for.
Name:	check valve.jpg
Old 02-10-2015, 06:46 PM   #4
Taranwanderer's Avatar
OP: when you say "nothing happens," do you mean you're not seeing or hearing anything? I know with mine, the only way I know it's working is that I can hear a slight hissing sound from the plumbing in the bathroom, and when I open the drain for the black tank, water is coming out. You're telling us that no water is coming out of your drain when you have the flush on?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 02-10-2015, 08:24 PM   #5
bubbles's Avatar
Attachment 69446
There is no input check valve for the factory installed black tank cleanout. There is however a backflow preventer in series with tank flush plumbing. It is mounted somewhere within your unit (under a sink, in a closet, in where the washing machine would be installed like mine or some other place). That puts it about 4' to 5' above your floor. Some are clear plastic and others are black plastic. I can hear the water input to my black tank but other than that the only real indication would be as stated previously "water coming out the drain with the flusher pressurized". One other thing, when you disconnect the hose from the flush out port there will probably be some residual back flow of water; Not to panic it will not be from your black tank just the residual flush water from the tube to the backflow preventer.
Old 02-11-2015, 02:23 PM   #6
XLR Production
The check valve is located in the bath lav. We ran into a rash of bad ones. Your dealer should be able to replace that for you
bulletbob is offline   Reply With Quote
Old 02-11-2015, 03:19 PM   #7
Jerry01's Avatar
How long are you running the water for? You do also have the black tank valve open as well? Mine took a minute or so for fluid to start coming out after turning the water on. And I only use the flush after draining the black tank. Jerry.
2005 GMC Sierra 2500HD, Duramax CC/SB
2022 Rockwood 2613 BS
Jerry01 is offline   Reply With Quote
Old 02-11-2015, 05:08 PM   #8
I've also been at a couple of campgrounds that have such low water pressure, it wouldn't force the check valve open. Have you only tried it from one water source?
taken is offline   Reply With Quote
Old 02-11-2015, 05:32 PM   #9
Witch Doctor's Avatar
I think I would go with his. Sounds like the backflow preventer is not opening.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-12-2015, 07:34 AM   #10
When i hook up the water and turn it on the water hose pressures up. I let it run for about 5 minutes and when i opened the black tank drain nothing came out of it. I will have it back at the dealer next week to fix some other issues i have found I will add this to my list.
Thanks for the help.
Old 02-12-2015, 07:40 AM   #11
Good Idea, when you use your black tank flush you can here it working at the toilet. If not you have a bad valve or a kink in the line. The line is made out of hose material not plex, so it can kink.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-12-2015, 07:52 AM   #12
sail2liv's Avatar
We have a hose that we only use for black tank....it has no pressure regulator like the fresh water hose that is for fresh water only....we get full faucet pressure into the black tank, so is important to have drain open in case roof vent is stopped up some...
if no leaks in system water should come out vent on roof...and we sure do not want that if we forget to open the main drain.....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 02-12-2015, 08:30 AM   #13
rattleNsmoke's Avatar
Crawl under your sink cabinet with a flashlight and look up for the valve. If it's clear, this should work.... Have a helper turn on the black tank flush and watch for water flow up into the valve. If working properly you'll see the water rush into it closing the spring assisted flapper, then run out the other end down into your black tank.
rattleNsmoke is offline   Reply With Quote
Old 04-05-2015, 10:44 AM   #14
My check valve was under bathroom sink and installed backwards from factory, I was able to take it apart and turn it around and all is well, good luck!
Billcincaelynn is offline   Reply With Quote
Old 04-08-2015, 05:14 AM   #15
I have the same problem with new 340x12. No flushing noise, no water out the waste hose.
Doreen & John
2015 XLR Thunderbolt 340x12HP
2015 F350 Lariat SC SB 4x4 6.7 SRW
2012 HD Ultra Classic
MN John is offline   Reply With Quote
Old 04-08-2015, 05:50 AM   #16
sounds like the check valve is installed backwards or faulty, very easy fix although I'm not sure where yours is located, maybe under your bathroom sink, it has a water line in and water line out, just unscrew both and turn it around and reinstall,, good luck
Old 04-08-2015, 11:52 AM   #17
XLR Production
It's probably the vacuum breaker in the bath lav. We had a rash of them that were made wring
Old 04-08-2015, 12:09 PM   #18
So should I remove, 180 it, and reconnect just in case it's installed wrong?
Doreen & John
Old 04-08-2015, 02:18 PM   #19
XLR Production
I'm guessing that it is another one made wrong. You can try if you like.
Old 04-08-2015, 02:40 PM   #20
Can or will you explain what good they are in the first place?
black, black water, water
