Old 02-10-2015, 09:11 AM   #1
Black water flush
I have a new XLR 340x12hp when i hook up my water hose to the black water flush nothing happens. Does it have a valve on the inlet side that needs to be opened in order for the flush system to work?
Tow rig: 2014 Ram 3500 CC
Old TH: 2007 376srv wildwood sport
New TH: 2014 340X12HP
rfregia is offline   Reply With Quote
Old 02-10-2015, 09:37 AM   #2
My XLR27HFS does not. Hook up the hose and turn it on.
breezyhillfarm is offline   Reply With Quote
Old 02-10-2015, 12:02 PM   #3
Could be a check valve problem, it might be stuck. Try taking the screen off and push it the plastic tab. Just make sure you stand off to the side when you push it in. The pic is of a regular fresh water connection but gives you an idea of what to look for.
Name:	check valve.jpg
Wiscampsin is online now   Reply With Quote
Old 02-10-2015, 05:46 PM   #4
Taranwanderer's Avatar
OP: when you say "nothing happens," do you mean you're not seeing or hearing anything? I know with mine, the only way I know it's working is that I can hear a slight hissing sound from the plumbing in the bathroom, and when I open the drain for the black tank, water is coming out. You're telling us that no water is coming out of your drain when you have the flush on?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 02-10-2015, 07:24 PM   #5
bubbles's Avatar
Attachment 69446
There is no input check valve for the factory installed black tank cleanout. There is however a backflow preventer in series with tank flush plumbing. It is mounted somewhere within your unit (under a sink, in a closet, in where the washing machine would be installed like mine or some other place). That puts it about 4' to 5' above your floor. Some are clear plastic and others are black plastic. I can hear the water input to my black tank but other than that the only real indication would be as stated previously "water coming out the drain with the flusher pressurized". One other thing, when you disconnect the hose from the flush out port there will probably be some residual back flow of water; Not to panic it will not be from your black tank just the residual flush water from the tube to the backflow preventer.
Old 02-11-2015, 01:23 PM   #6
XLR Production
The check valve is located in the bath lav. We ran into a rash of bad ones. Your dealer should be able to replace that for you
bulletbob is offline   Reply With Quote
Old 02-11-2015, 02:19 PM   #7
Jerry01's Avatar
How long are you running the water for? You do also have the black tank valve open as well? Mine took a minute or so for fluid to start coming out after turning the water on. And I only use the flush after draining the black tank. Jerry.
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 02-11-2015, 04:08 PM   #8
I've also been at a couple of campgrounds that have such low water pressure, it wouldn't force the check valve open. Have you only tried it from one water source?
taken is offline   Reply With Quote
Old 02-11-2015, 04:32 PM   #9
Witch Doctor's Avatar
I think I would go with his. Sounds like the backflow preventer is not opening.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-12-2015, 06:34 AM   #10
When i hook up the water and turn it on the water hose pressures up. I let it run for about 5 minutes and when i opened the black tank drain nothing came out of it. I will have it back at the dealer next week to fix some other issues i have found I will add this to my list.
Thanks for the help.
black, black water, water
