Old 08-22-2011, 09:23 PM   #1
Steve38's Avatar
Black water tank flush
The idea of pulling a garden hose into the bathroom to flush the tank, not too appealing to me. For about $15 i bought this handy device. I did not the buy the one that claims to turn. Most reviews were negative. This one just sprays the inside of the tank from static holes drilled in the nozzle. Very easy install.
I added a few feet of garden hose to gain access. (the tank is behind the axle)
ID:	7558   Click image for larger version
ID:	7559   Click image for larger version
ID:	7560   Click image for larger version
Steve38 is offline   Reply With Quote
Old 08-22-2011, 10:36 PM   #2
Herk7769's Avatar
Make sure you always use a backflow preventer on the hose end.
You should also install an anti-siphon valve to prevent black water from entering the flush hose and siphoning it out the inlet while you drive.
HAM CALLSIGN - KC3FFW
Old 08-22-2011, 10:48 PM   #3
Fire Instructor's Avatar
They normally get sold with the anti-siphon with the kit. Make sure that you use it, otherwise, although a long-shot, you could really contaminate a water system badly.
Also, don't forget the winterize that line when you put your unit away for the winter. The water in the hose and sprayer will freeze and damage it. I just blow it out with compressed air.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 08-22-2011, 11:05 PM   #4
Steve38's Avatar
The anti siphon is built in. I store my trailer inside a heated building. I winterize in case the power fails. But thanks for the tip.
Old 03-31-2012, 12:17 AM   #5
Steve, like the idea on the flush. Better than letting the kids fill up the black water by running the fresh water. What did you do to mount the hose on the outside?
GaryRudolph is offline   Reply With Quote
Old 03-31-2012, 08:36 AM   #6
Steve38's Avatar
Yes, i ran a few feet of hose for easy access
Old 03-31-2012, 01:18 PM   #7
You just hang it underneath or drill the side?
Old 03-31-2012, 02:04 PM   #8
Steve38's Avatar
I did the side so water will spray the length of the tank. It works well. I have a clear extension on the drain before the macerator pump. I was surprised at the amount debris it washes out.
Old 03-31-2012, 02:09 PM   #9
Steve38's Avatar
I can post more pics if it will help.
ID:	11508   Click image for larger version
Old 03-31-2012, 02:37 PM   #10
GASPEDDLER's Avatar
Steve, did you mount the loose end of the hose to the side of your trailer for easy hookup to a fresh water source? Or is the hose simply tucked up/coiled up underneath your TT? Where did you purchase the kit?
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
black water
