Originally Posted by habdave
2016 XLR 29HFS cable from park is active however when hooked to trailer none of my TV's inside( 3 separate rooms)can get a cable signal. Get air signals through antenna fine. Tried using satellite jack but nothing there either ( just in case it was wired backwards) Can anyone offer any suggestions.
HD, Our trailers should be just alike, but not sure if colors match. CG cable comes to the "booster" outlet on a black coax. Lets call it a booster, not amplifier - the booster on the antenna, this is just the switch and power supply for it. The antenna coax is orange and "other" outlets on a gray coax, which actually feeds a splitter, then on to the other outlets (bedroom and toy bay).
The satellite coax only comes into that one outlet and stops (ready to add your receiver there.
Others have correctly stated this: You can't have multiple boosters, but when the booster button is depressed the light comes on and antenna is switched to the all television outlets; when it is not depressed the light is not on and CG cable is switched to all outlets.
You have to have a good OTA signal and have to option your TV(s) for the correct input. I select TV for antenna or cable on mine. To get sat. to TV, I feed that one TV via HDMI. Getting HDMI to multiple TVs is for another discussion.
If this doesn't help, remove the booster outlet and look at the cables on it. I have seen on the forum (can't remember who) the other sets (gray cable) wasn't connected to anything. The splitter, BTW is in the ceiling at the booster outlet and can be pulled out of the ceiling for maintenance.
I can't post a pic, but here's a link that might be helpful, if I can post it.
FTLS - Broadcast/Cable TV
WW
