Old 04-10-2015, 08:07 PM   #21
Originally Posted by northstar1960 View Post
i have not found an outside hook up for cable or sat . is there one if so where ?
PH,
From the videos I have watched, it should be right above the outlets right by the main door.
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 04-10-2015, 08:57 PM   #22
XLR Production
On the 29hfs, the cable inlet is on the off door side next to the power cord inlet. Until recently we were only running cable not satellite.
bulletbob is offline   Reply With Quote
Old 04-10-2015, 09:25 PM   #23
Play Harder's Avatar
NorthStar
Mine is here
Name:	ImageUploadedByForest River Forums1428719014.372759.jpg
I did request sat input on my build
So don't know if that's standard- it's easy to convert a cable only one to do both though.
Play Harder is offline   Reply With Quote
Old 04-11-2015, 07:23 AM   #24
Taranwanderer's Avatar
I'm hoping I might have had something to do with that decision...Thanks again to Mike C at XLR for my dramatic satellite conversion/install...
Good luck with the HDMI deal, sounds like wireless might be the least painful but most $ way to go...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 04-11-2015, 09:29 AM   #25
WolfWhistle's Avatar
Mine only had Cable connection outside. I did a little change at the television outlet (antenna and cable) to allow connection to Dish receiver as well splitting it to the television, for times I only want to use the OTA antenna or have a CG cable feed. I fed the tele with HDMI from the receiver and only have the one tv. I have a 50' HDMI cable in the house without a problem. There are different HDMI cable technologies, but I am not up on them. I looked at my unit yesterday and eyed the air conditioner ducts for possible HDMI cabling. I don't know how they / it would work with the bends, but it looks like a good option. A strong point is that the cable length would be much shorter than running under floor.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 04-11-2015, 09:59 AM   #26
northstar1960's Avatar
Originally Posted by stevejd235 View Post
PH,
Thanks . heading out today to the unit and will have another look .
northstar1960 is offline   Reply With Quote
Old 04-11-2015, 10:03 AM   #27
Originally Posted by Play Harder View Post
NorthStar
Mine is here
Attachment 73860
I'll check it out today . i won't be using the antenna as out west where i am very little if any over the air tv .i will most likely remove the antenna and install the dish up there . i have the wineguard auto find dish
