Old 06-10-2019, 08:40 PM   #1
Taranwanderer's Avatar
Check your battery box!
Towing the XLR today, to the dealer for inspection, and a car pulls up next to me and starts pointing.😡. I pull over, and what do I find? The crappy plastic battery box that hangs through the floor of my storage storage compartment (with nothing beneath it) has decided to crack and break. The battery is hanging down from the cables and dragging on the asphalt. Of course, itís been dragging long enough that itís worn through the bottom of the case, and all the electrolyte leaked out.
Great engineering, Forest River! 🙄. Will be reinforcing this bad design shortly.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (Ď18)21 (Ď19)11
2016 Ford Fusion Titanium (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 06-10-2019, 08:54 PM   #2
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
Happened to my 2014 XLR Thunderbolt...it's a poor welding job by LIPPERT
2014 XLR 415AMP, 2019 Sandpiper 379FLOK, F350 Lariat 6.7 DRW, NRA Benefactors.
dwhit is offline   Reply With Quote
Old 06-10-2019, 09:17 PM   #3
Bluepill's Avatar
Lippert?
Bad Welding?
You mean like this:
Bad wire routing by FR.
Old 06-10-2019, 10:02 PM   #4
Oh, this wasnít welding. Welding would imply that the part that failed was made of metal.🙄 This was entirely due to the thin white plastic battery box which degraded and became brittle over time. It just picked today and Pennsylvania pot hole #5380 to shatter and drop my battery into the nothingness below it. But still a poor design.
Old 06-11-2019, 02:26 AM   #5
bikendan's Avatar
Batteries and their boxes are DEALER-INSTALLED items on towables, not the manufacturer.
Equalizer WDH
Old 06-11-2019, 06:07 AM   #6
That may be true, but itís still a FR designed spot for it, regardless of who installs it, and itís still seems like a bad design idea to put your 50# battery in a hole in your forward storage compartment in a flimsy plastic battery tray (that will degrade over time with exposure to the elements and sun) with nothing solid beneath it (except the highway.)
Oh, and this is a 5-er, not a tow behind. But I think the dealer does the install regardless on both types.
Old 06-11-2019, 12:47 PM   #7
rlh1957's Avatar
I keep saying anyone can be president and anyone can get a job as engineers and designers in the RV Industry. Only study required is that you pass the LAR Engineering exam... given weekly at Bubba's outback shed! LAR --- "Looks About Right" engineering. And it isn't even about saving money, it is piss poor design and assembly. Obviously inspection of welds isn't done by a journeyman welder.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is online now   Reply With Quote
Old 06-11-2019, 01:06 PM   #8
CC4
CC4's Avatar
Not the exact same problem but shortly after I purchased my TT I was routinely checking over the trailer and for some reason opened the battery box. Filled with water up to a half inch below the terminals. If I had been pulling it would have shorted and caused all types of problems. No vent holes on the plastic container but with heavy rains water could get into the box. I ended up drilling some weeping holes in the bottom of the box and then inserting a raised plastic strip below the battery so that now if water gets in it can drain through but the battery is still fully protected from below and above. When I took my battery out for storage last fall it was 'dry as a bone' so I guess I did the right thing. No welding issues (knock on wood) but I have had to replace the stabilizers due to a bending issue. The ones that came with the trailer were under weight rated (as far as I was concerned) so when one bent I bought after market stabilizers and re-drilled the mounting holes so that the new ones are rated more than double the stock units. No problem since I did that. Of course there was the sink plumbing issue on the first camp out when water was coming out from under the cabinet and onto the floor. I had to replumb the kitchen drain temporarily until, on the way home, I dropped it back to the dealership where I had them reinforce and support all the drain pipes at their cost. While there they found that the cabinets also needed to be reinforced and that there was a manufacturing flaw on the front exterior panels that required warranty replacement. Three weeks later I picked up my newly repaired trailer and headed directly out for my next excursion to the lake and everything has been fine since then. That was four years ago,
CC4 is offline   Reply With Quote
Old 06-11-2019, 02:53 PM   #9
bikendan's Avatar
A 5th wheel IS a towable, which is what I posted.
I never said tow behind.
Popups, TTs and 5th wheels are classified as Towables.
The only factory installed batteries are in motorized units.
Equalizer WDH
Old 06-11-2019, 10:26 PM   #10
Gotcha. But my point about poor design/placement still stands. Who installs it is kind of irrelevant. 🤔
battery, check
