Old 12-07-2015, 06:22 PM   #1
Christmas Gift Upgrades
So, the family (bride and mother) were asking for Christmas ideas. Looks like a couple are en route. The last was too much $. Perhaps I can gift that to myself...
1) RV Snap Pad rubber pads for the 6 Level Up landing gear feet. No more lining up pads or blocks as they are lowering. These are on for life and make "one touch leveling" more one touch than before...
Automatic RV Leveling Jack Pads - RV SnapPad
2) MorRyde HD shackle kit. I've wanted to update the smallish stock Dexter shackles since I got my rig but haven't gotten around to it. MorRyde makes a kit with all the shackles and longer wet bolts to accommodate. The kit for my specific application isn't on their website so it's a call to order thing to make sure you get the right quantities. Part # UO12-030.
Heavy Duty Shackle Kit Upgrade - MORryde Products
3) From me to me... Wilson Electronics just came out with an RV specific cell phone booster. I had a pieced together home/auto setup in my last hauler that worked great but involved extensive permanent installation. The new "RV 4G" system can utilize your existing satellite coax inlet if your not using it to connect the outside antenna to the inside one which you can hide behind your LR TV where the satellite coax ends up anyway. Then, when needed, hook up the outside antenna to the inlet and hang on or near your RV for great signal inside. It can't give signal where there is none, but my past experience has gotten me from 1 bar outside only to 3-4 bars inside the RV. It's not only a help on the phone end but we also use my phone as a hotspot to our laptop when no park WIFI is available. Need good signal for that!
https://store.weboost.com/products/rv-4g
Now to hope I've been good so my Santa's all come through for me...
Karl4Cat is offline   Reply With Quote
Old 12-07-2015, 07:42 PM   #2
ferguson65's Avatar
Like the pads and the shackle kit. Both are mods I'd like to make somewhere down the line. Curious how the booster works if you "santa" it for yourself, though I kind of enjoy going camping and having the phone not work.
Most of the camper stuff I wanted I had to order myself this year..............unless Santa will send one of his elves to install it all Christmas night!
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 12-07-2015, 08:01 PM   #3
I hear you on the phone thing but I love having info at my fingertips. Data is the more important component of the signal boost.
Will post if I actually end up with any or all and their actual value in the field...
Old 12-07-2015, 08:06 PM   #4
Kenny kustom's Avatar
Do the booster!
You Can be the Guinea pig!
I'm interested if it works!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I AM NOT THE WEIGHT POLICE...
2017 Dynamax Isata 4
Old 12-07-2015, 08:11 PM   #5
My CC does give me a 10% discount on Amazon this month Kenny. $40 down, $360 to go...
Old 12-07-2015, 08:29 PM   #6
asquared's Avatar
I'm curious,as too how well that booster ends up working for you.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 12-07-2015, 08:32 PM   #7
Like I said, I had one in my last rig and I run a Wilson unit at my home as well. The one at home took me from 1 bar with my cell phone in the window sill only to 3-4 all throughout the first floor. I'm hoping the RV unit will be similar or my CFO will have my head...
Old 12-07-2015, 08:33 PM   #8
Does it help with data?
2016 Sabre 36QBOK
Old 12-07-2015, 08:40 PM   #9
Oh absolutely. Data is why I really wanted it as I like to hotspot my laptop off my phone. Boosted signal is boosted signal. It goes up for all a phone can do...
Old 12-07-2015, 09:16 PM   #10
tmilicia's Avatar
I'm liking those snap pads, maybe Santa can drop a set by my place.
2016 FR XLR Thunderbolt 395AMP
2015 Ford F350 CC SB 4x4
tmilicia is offline   Reply With Quote
upgrade
